Hello everyone, I have noticed that some screws in my Ikea Metod kitchen cabinets have become loose over time. This mainly affects the screws that hold the cabinet doors and the connecting fittings. I am now looking for an effective and long-lasting way to tighten or repair these loose screws without them coming loose again or damaging the material. What experiences have you had with this? Are there specific screws, adhesives, or methods that have proven successful? I would like to avoid having to remove the entire cabinet front or hiring professional help if possible. Thank you in advance!
In addition to the threaded insert method, I recommend the following steps:
- Regularly clean the threads to remove dust and wood debris
- For hinges, it is often useful to use original screws together with small plastic washers to distribute the pressure evenly
- If the drill hole is too large, you can use wood glue as filler before screwing in an insert
- It is important to tighten slowly and evenly to avoid cracking the material
Another alternative to threaded inserts are wood screws with special thread design, but be careful not to screw them in too deeply.
I would like to clarify: Standard Metod particle boards have a surface layer that can reduce grip when screws are removed. A common and tested solution is to use so-called wood repair fillers combined with short drying times. - Remove the loose screw - Clean the hole thoroughly, removing all old glue or debris - Apply the repair filler into the hole according to the instructions - After curing, drill a new hole with a small drill bit (e.g., 2 mm (0.08 inches) smaller than the screw thread) - Use new original Metod screws - Screw them in with moderate torque This helps to increase the volume and density around the hole, providing better holding power. In the hinge area, it is recommended to replace screws with original spare parts if needed, especially if the head is damaged or deformed.
Palenar schrieb:
Carefully screw in the threaded insert using a special tool or by hand The method with the threaded insert sounds interesting, but I don’t have the right tool yet. Is it possible to install it without specialized equipment, or does the material structure suffer significantly? I would prefer not to enlarge the hole too much, as you don’t want to damage the cabinets. Is there an alternative way to install threaded inserts without much effort or craftsmanship? Also, @Jodyro mentioned that Ikea boards often don’t have enough material thickness for large inserts. What is your critical assessment of this? Is there a minimum board thickness required for this?
barEsperan29 Jun 2022 12:11Regarding the last question: For threaded inserts, you need a minimum material thickness of around 15-18 mm (0.6-0.7 inches); otherwise, the inserts won’t fit properly or may cause the edge to split. With Ikea Metod, this is generally suitable since 16 mm (0.6 inches) particle board is used. If you don’t have special tools, you can screw in the threaded inserts by hand using a screwdriver or Allen key, but turn slowly and watch out for edge breakage. If the hole is too large, pre-treating the insert with some wood glue can help hold it more firmly. Alternatively, metal brackets can be used to stabilize connections without needing to insert new inserts directly into the wood.
