Hello everyone, I am currently planning my kitchen renovation and considering whether to use the Ikea Metod corner cabinets. My main question is how durable and functional these corner cabinets really are in everyday use. Specifically, I am interested in how well the storage space can be utilized, whether the doors or drawers operate smoothly, and how stable the hinges and mechanisms remain after extended use. It would also be helpful to hear if anyone has experience with the different corner cabinet solutions – for example, carousel or Le Mans pull-outs. I appreciate any practical tips, personal experiences, and also advice on problems or limitations to keep in mind. Thanks in advance!
Z
zarJody6827 Jul 2022 11:07Based on my personal experience, the Ikea Metod corner cabinets are stable under typical kitchen use, and the load capacity of the shelves adequately supports regular household items. However, it is important to ensure proper assembly of the cabinets and to carefully check the fastening points.
Storage use in corner cabinets is indeed challenging. The carousel is suitable for smaller items that are frequently needed, but it requires some space when opened. I have found the Le Mans pull-outs to be noticeably more convenient, as they provide better accessibility, although they are somewhat more expensive and more complex to install.
Regarding hinges: Ikea uses sturdy fittings here that generally do not cause issues even after several years of normal use. Occasional adjustment is not uncommon.
I would like to add that when planning, the dimensions of the corner cabinet should definitely be taken into account. Ikea Metod corner cabinets are standardized, with a depth usually around 60 cm (24 inches), which is sufficient for many kitchens. When choosing between a carousel and a Le Mans system, you should also consider your actual storage needs: carousels offer slightly less volume but are more affordable.
Another important aspect is the door opening angles, which can sometimes be problematic in small kitchen spaces. A carousel requires more space when the door is fully open, which should be considered in compact rooms.
The quality of Ikea’s hinges and fittings is reasonable for the price; however, screws should be tightened only to a moderate level to avoid damage. The mechanism should be lubricated occasionally to keep the doors operating smoothly.
About a year ago, I installed an Ikea Metod corner cabinet with the carousel system and am generally satisfied. At first, I was a bit unsure whether the carousel would be practical for everyday use since it needs to hold a lot of dishes and spices in my kitchen. What helped me was to organize everything systematically instead of just stuffing it all in.
The doors on my cabinet operate quite smoothly, but I have noticed that the hinges need occasional adjustments, especially with frequent use.
One more tip: Before installation, definitely check that the cabinet base is firm and stable, as otherwise the carousel could get stuck. This was a concern for me, but so far it has worked flawlessly.
I have been using the Le Mans pull-out system in my Metod corner cabinet for two years and have had a very positive experience. The pull-outs are easy to extend and provide significantly better access compared to a standard carousel. Especially when it comes to larger or bulky items, the handling feels much more intuitive.
Installing the Le Mans pull-outs is somewhat more complex and requires careful planning, particularly regarding the measurements, because the pull-outs take up more space.
I completely agree and recommend carefully calculating beforehand whether there is enough space for the mechanism.
zarJody68 schrieb:
I have found the Le Mans pull-outs to be noticeably more convenient due to better accessibility, but they are also somewhat more expensive and complicated to install.
One important aspect I consider is the long-term durability of the components. Ikea Metod has been established for years, and there is enough user feedback indicating that especially on heavily used hinges, problems can sometimes occur if the installation is not done carefully.
Therefore, my advice is to take your time during installation, use the appropriate tools, and read the instructions thoroughly. This can help avoid later adjustments or even the need to replace parts. Additionally, it is recommended to maintain the hinges with a suitable lubricant to ensure smooth operation over time.
