Hello everyone...
After our first floor plan attempt failed completely, we worked with the architect to develop two more ground floor versions and one for the upper floor. I would like to know which ones you find good or bad, and what you generally like or dislike about the floor plans?! Also, the pantry door is drawn a bit oddly; it won’t actually look like that...
Development plan/restrictions
Plot size approximately 480 square meters (5167 square feet)
Slope: No
Floor area ratio: No
Building coverage ratio: No
Building envelope, building line and boundary: 19 meters (62 feet)
Edge development: No
Number of parking spaces:
Number of floors: 1.5
Roof shape: gable roof
Architectural style: modern
Orientation: terrace to the west, bay window to the south
Maximum heights/limits:
Additional specifications:
Homeowners’ requirements
Style, roof shape, building type:
Basement, floors: no basement
Number of occupants, ages: 2
Occasional guests per year: family occasionally
Open or closed layout: open
Conservative or modern building method:
Open kitchen, kitchen island: open kitchen
Number of dining seats:
Fireplace: no
Music/sound wall: no
Balcony, roof terrace:
Garage, carport:
Utility garden, greenhouse:
Other wishes/special features/daily routine, including reasons why certain things should or should not be included
Who created the plan:
- Architect: yes
- Do-it-yourself
What do you particularly like and why?
What do you not like and why?
Preferred heating system:
Heat pump
If you have to give up something, which details or extensions:
- can you do without
- cannot do without:
Open kitchen, guest room, window in every room
Slope: No
Fireplace: no
Garage, carport:
- Architect: yes
- Do-it-yourself
Heat pump
If you have a back door through the utility room, people come in there with dirty feet. This door also has a handle that allows opening without a key and without a doorbell. Children should always use this door. Adults too. Only the mail carrier and important guests, who ideally leave again soon, use the front door. Everyone else goes in through the back. So, there is absolutely no problem with the staircase down there. Karsten
Our staircase also starts right by the door. Based on our current experience, I would look for a different solution today, as the vacuum cleaner is stored within easy reach under the stairs.
Meanwhile, the stroller also moves through this area, and it’s difficult to clean the wheels properly, which means even more dirt in this “transition zone.”
Maybe someday we will build a glazed vestibule in front of the main door, but you shouldn’t think too much about the cost-benefit ratio.
Our bed is placed in a 50cm (20 inch) knee wall, set forward about 80 to 90cm (31 to 35 inches). That means there is around 40cm (16 inches) of space behind the headboard for storage. You can’t sit upright there, so reading has to be done in the living room, but at least you don’t bang your head when getting up.
Don’t make it so complicated. That’s what robot vacuum cleaners are for nowadays. They can be programmed to vacuum the entire hallway at least once a day, so you can comfortably walk barefoot to and from the stairs.
Ev-Marie8619 May 2017 15:42Stairs aside... Dressing room aside... what do you think now about my "masterful" drawing of a proposal..
Ev-Marie86 schrieb:
Stairs on one side... Dressing room on the other... what do you think about my “masterful” sketch of a proposal..?Where?
Best regards in short
Ev-Marie8619 May 2017 15:50Yes, the hand-drawn one... I’ll only send something to the architect again once it fits... otherwise, she thinks I’m silly... Changing it every five minutes... Are there any improvement suggestions?
