Hello everyone...
After our first floor plan attempt failed completely, we worked with the architect to develop two more ground floor versions and one for the upper floor. I would like to know which ones you find good or bad, and what you generally like or dislike about the floor plans?! Also, the pantry door is drawn a bit oddly; it won’t actually look like that...
Development plan/restrictions
Plot size approximately 480 square meters (5167 square feet)
Slope: No
Floor area ratio: No
Building coverage ratio: No
Building envelope, building line and boundary: 19 meters (62 feet)
Edge development: No
Number of parking spaces:
Number of floors: 1.5
Roof shape: gable roof
Architectural style: modern
Orientation: terrace to the west, bay window to the south
Maximum heights/limits:
Additional specifications:
Homeowners’ requirements
Style, roof shape, building type:
Basement, floors: no basement
Number of occupants, ages: 2
Occasional guests per year: family occasionally
Open or closed layout: open
Conservative or modern building method:
Open kitchen, kitchen island: open kitchen
Number of dining seats:
Fireplace: no
Music/sound wall: no
Balcony, roof terrace:
Garage, carport:
Utility garden, greenhouse:
Other wishes/special features/daily routine, including reasons why certain things should or should not be included
Who created the plan:
- Architect: yes
- Do-it-yourself
What do you particularly like and why?
What do you not like and why?
Preferred heating system:
Heat pump
If you have to give up something, which details or extensions:
- can you do without
- cannot do without:
Open kitchen, guest room, window in every room
Slope: No
Fireplace: no
Garage, carport:
- Architect: yes
- Do-it-yourself
Heat pump
Ev-Marie8616 Apr 2018 18:10We did that in the last plan. However, different windows were installed due to the lighting conditions. Nothing is allowed to be changed afterward. That has already been rushed. And the larger windows cannot be moved further out. But we only found that out now.
kaho674 schrieb:
A mason is not stupid. Moving a window a few centimeters to the right or left doesn’t bother them at all. [...] And the roller shutters will move along, obviously. Were you thinking of your own words here:
kaho674 schrieb:
Take another look at the exterior view, Ev-Marie86 schrieb:
that because of the gable and the proximity to the roof, it can’t be moved.. I took a close look at the exterior and came to the conclusion: a) a 62.5 cm (25 inches) shift (for the bedroom and kids’ room, each towards the roof edge) should be possible; b) the maintenance hatch of the roller shutter might then directly abut the finished roof soffit at one corner. Therefore, the option
kbt09 schrieb:
You could also just make the bedroom window narrower. possibly combined with this, would be “the solution” – I’m thinking about 25 cm (10 inches) narrower.
Ev-Marie86 schrieb:
Nothing is allowed to be changed afterwards at all.. Which authority states that – the prime minister personally? – Adjustments are always possible. And this is a completely standard one; it certainly won’t be a first for the professionals.
Ev-Marie8616 Apr 2018 18:26The developer says this: We received the final building plan three weeks ago. According to the developer, no changes were allowed after that point. So submitting it earlier would not have made any difference. Windows and masonry cannot be altered, except for a high additional cost.
Ev-Marie86 schrieb:
Windows and masonry must not be altered. Amen. Where there is a will, there is a way.
Either a cabinet width of max. 270 cm (106 inches) is sufficient, or the builder will have to be bothered once again.
