ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
What do you think about the floor plans?
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Shiny86 schrieb:
Regarding the shower: I’m thinking about old age. I could later separate the living room to create a bedroom and turn the dining area into a living room. Then I could still shower downstairs if I’m no longer able to climb stairs. What do you think about this? I still think the same as last month / last year...
Your generation is very likely to build a new house close to retirement instead of renovating a newly built house.
haydee schrieb:
All the floor plans are missing storage rooms.
Where do you put Christmas decorations, suitcases, and outgrown children’s items waiting for the next child?
I can already see boxes standing in the kids’ rooms and the walk-in closet.We have a few square meters in the attic for that. Otherwise, we use the storage space under the stairs. However, we live quite minimally and don’t accumulate much. For example, no third child is planned, and anything that is no longer needed over time I either sell, give away, or donate immediately.
Suitcases and Christmas stuff go up to the attic, even though it’s inconvenient. But those things aren’t needed very often.
Shiny86 schrieb:
The living room is only 4.4 m wide (14 ft 5 in) now because of the built-in staircase, right? More due to budget. You can adjust the length at the back yourself, either longer or shorter.
Shiny86 schrieb:
And does the staircase have two landings now, or does it just look like that? My software can’t draw staircases. Those are minor details and not important. What matters is that there is enough planned space.
ltenzer schrieb:
Are there already houses on your street side that you can use as a reference? Or will you be the first ones building on this slope?
I would generally agree with adding fill if a basement is not an option for you. Which region are you building in? In some areas, fill gravel is currently inexpensive because gravel pit operators urgently need space for soil excavation deposits.
What are the limits on how far you can raise the ground? You can model suitable slopes from the terrace accordingly. As long as you only need one exit from the terrace to the garden, I don’t see major issues with that. No, there is no house yet. We are among the first to build here... A basement is not an option. We are building in the Bergisches Land/NRW.
I planned the terrace in the dining area, as it's closer from the kitchen. The garage will be further away, on the left side of the house.
Would you be able to show a photo of your sister’s terrace/garden? That sounds good.
We would probably only make a path from the terrace to the garden. But I’m not sure yet how to do that. I want to build up the ground. But I don’t fully understand it yet.
You can apparently set the house as high as you want, but not the garden — only with neighbors’ permission, and who knows when they might build. On the left and right sides, filling up may only be allowed within limited boundaries.
