Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
driver55
17 Nov 2021 09:26
Tom1978 schrieb:
Unfortunately, the rainwater tank has been dropped due to delivery times.
Great planning. 🙄 You’ve known since forever that you want/need one.
The building permit / planning permission took over 10 months anyway.
TmMike_2
17 Nov 2021 09:28
driver55 schrieb:
Great planning. 🙄 You’ve known for a long time that you want/need one.
The building permit / planning permission took more than 10 months.
Why not install the cistern after the house? Buy the materials yourself and you probably know an excavator operator who could set it up for you on a Saturday.
motorradsilke
17 Nov 2021 09:30
driver55 schrieb:
Great planning. 🙄 You have known for a long time that you want/need one.
That was my first thought as well.
But unfortunately, orders usually aren’t placed until everything is certain. It was the same with our interior doors. Samples were chosen in April, the door installer came back in August to take all the measurements, and by mid-October when we moved in, the doors weren’t immediately available, so they could only be installed in mid-November.
Tom1978
17 Nov 2021 09:31
driver55 schrieb:
Great planning. 🙄 You’ve known since a long time that you wanted/needed one.
The building permit / planning permission took over 10 months.
It wasn’t mainly our fault, but the earthworks contractor’s. He assumed delivery times of a maximum of 5 working days. It’s now 15 days. The idea for the drainage system came from the forum. And if that needed to be installed, the rainwater cistern should be located nearby. I only found out yesterday that this would make the construction access road twice as long.
General question. What is your post meant to convey now? Bad mood, trolling, or just venting frustration? 😎
TmMike_2
17 Nov 2021 09:33
But unfortunately, orders are usually only placed once everything is confirmed. It was the same with our interior doors. They were selected in April, the door installer came back in August to take measurements, and by mid-October, when we moved in, they weren’t immediately available, so they could only be installed in mid-November.
Tom1978 schrieb:
It wasn’t mainly our fault, but the earthworks contractor’s. He expected a maximum delivery time of 5 working days. It has now been 15 days. The idea for the drainage trench came from this forum. And if that needs to be installed, the rainwater tank shouldn’t be far from it. I only learned yesterday that the construction access road would be twice as long as planned.
General question: What is your post supposed to say? Bad mood, trolling, or just venting frustration? 😎
I would position the tank where it’s least bothersome. Possibly near the construction access road; if that interferes with later access, I’d install the tank last. And even if it’s 20m (65 feet) away from the drainage, just lay one meter (3 feet) of pipe to connect it.
motorradsilke
17 Nov 2021 09:38
Tom1978 schrieb:
General question. What is your post supposed to say? Bad mood, trolling, or just venting frustration? 😎
I don’t understand why the civil engineer’s failure is being blamed on you now. He is aware of the current situation and should have clarified the delivery times beforehand. If he missed that, he must cover the additional costs.
