ᐅ Combine cistern and rainwater inspection chamber?
Created on: 3 Apr 2022 20:00
Seb_Opf
Seb_Opf
3 Apr 2022 20:00
Good evening,
according to the zoning plan, a cistern must be built on the property. The drainage is carried out via a separate system.
So, two manholes and a cistern are required. From a technical point of view, is it possible to combine the rainwater inspection chamber and the cistern into a single structure to save some effort, or can I skip calling the authorities?
Thank you
TmMike_2
3 Apr 2022 20:54
So-called infiltration cisterns "3 in 1" do exist, just googled it.
Seb_Opf
3 Apr 2022 20:56
No need for infiltration...
TmMike_2
3 Apr 2022 21:04
Signs signs
Check with your local authority if it’s allowed; it could save you money. Otherwise, the overflow from the cistern goes into the municipal drainage system, right? Where I am, it’s common to have to insure it yourself. But there are no fees for that. I think I have about 500m2 (5400 sq ft) of impermeable surface, just the house, garage, and driveway. If you have to arrange disposal, it would probably be quite expensive.
Nida35a3 Apr 2022 21:06
Seb_Opf schrieb:
or can I just skip calling the administration?
If you call or inquire, the administration is required to respond or decide according to the legal situation.
Questions that are not asked do not have to be negatively decided.
TmMike_2
3 Apr 2022 21:07
Nida35a schrieb:
If you call or inquire, the administration must respond or decide according to the legal situation.
Questions that are not asked do not have to be decided negatively.
Yes, but if you have to pay for stormwater anyway, making a call can also have a positive effect.
