ᐅ Cistern in the garden / driveway
Created on: 31 Jan 2020 22:28
Piotr1981
Piotr1981
31 Jan 2020 22:28
We are planning to build or buy a rainwater cistern. Has anyone here had experience with this? The cistern is primarily intended for garden irrigation.
According to the development plan, rainwater infiltration on the property is not allowed.
Concrete?
Plastic?
What else should we consider?
Toilet connection?
Where to position it?
I would like to take this into account directly during the excavation for the foundation slab and have the hole dug at the same time.
Looking forward to your ideas and tips.
One001 Feb 2020 03:35
there are plenty of ideas and tips available; just try using the search function:
https://www.hausbau-forum.de/search/115889/?q=Zisterne&c%5Btitle_only%5D=1&o=date
dab_dab
1 Feb 2020 19:25
In addition to precise drainage planning and possibly an irrigation system, I would recommend including a suitable filter right from the start and installing a generously sized conduit pipe, for example, from the rainwater cistern to the equipment room. This way, you will have all options available up to the maximum level of house utilization. If you want to take full advantage of this, besides a domestic water pump system, you will also need appropriate water pipes leading to the points of use.
But most importantly, the exact elevation levels of the connection and transfer points must be determined, along with attention to backflow prevention levels.
Choose a branded product; then, regardless of the material, the load-bearing capacity is usually not an issue.
Piotr1981
1 Feb 2020 19:30
dab_dab schrieb:
In addition to careful drainage planning and possibly irrigation planning, I would recommend including a suitable filter from the start and installing a generously sized conduit pipe for technical installations, for example, from the cistern to the utility room. This way, up to the maximum level of house usage, you basically have all options available. If you want to use these options, you will need not only a domestic water system but also the necessary water pipes to supply the appliances.
But the most important thing is to determine the exact elevation levels of the connection and transfer points and to consider backflow levels.
Buy a branded product; then, regardless of the material, driveway load capacity is usually not an issue.
What exactly do you mean by drainage/irrigation planning? Do you have a cistern yourself? What do you mean by conduit pipe for technical installations? Maybe you could send me detailed tips via private message.
kaho6741 Feb 2020 19:31
We had to build two cisterns for firefighting water, which we are now allowed to repurpose. Back then, the two units cost around 5,000 euros including installation for 23,000 liters (6,079 gallons). Connecting them to the household drainage was quite straightforward – the planning of the irrigation system is much more complex.
Piotr1981
1 Feb 2020 19:34
kaho674 schrieb:
We had to build 2 cisterns for firefighting water, which we are now allowed to repurpose. Back then, the two units cost about 5,000 euros including installation for 23,000 liters (6,070 gallons). Connecting them to the household drainage was relatively straightforward – the irrigation system planning is much more complex.
23,000 liters (6,070 gallons)?
We were recommended a maximum of just under 5,000 liters (1,320 gallons).
Generally, I mainly want to water the garden and possibly also use it for the toilet, if it’s not too complicated. I really have no idea. I’ll have to discuss it with my architect.
