ᐅ Bathroom Planning – No Suitable Solution for the Bathroom
Created on: 16 May 2023 14:41
Stein2023
we are struggling with our bathroom layout, including the plumbing plan. I hope I can explain the conditions clearly:
- Dimensions: 3.50 by 4 meters (11.5 by 13 feet)
- Below the bathroom is the guest room. Most likely, there will be a plumbing line coming down at one corner, which is acceptable. Two plumbing lines are a no-go.
- The two windows can still be moved a few centimeters.
- We are completely flexible with the two doors.
- In the bathroom, we would like: a walk-in shower, a double sink, washer and dryer (here a countertop can be used to cover a possible half-height partition wall. That means the countertop can be placed on top of the half-height partition wall)
I can’t manage to combine all components without needing a second plumbing line. Is it perhaps possible to install sanitary fixtures on the opposite wall and route the drain pipes to the other wall? Maybe we are overcomplicating things?
Here is one solution where we can route the plumbing from the sink around the corner workspace:
Grundriss eines Badezimmers mit Toilette, Waschbecken und rotem L-Möbel; angrenzende Ankleide.
3D-Küchen-Grundriss von oben mit Spüle rechts und Holzboden.
Does anyone have suggestions for optimization? We are not happy with the current solution.
hanghaus2023
23 May 2023 09:39
Your last design might force you to run the wastewater pipe right through a wall on the ground floor. I’m not in the mood to look for the ground floor right now.
Stein2023
23 May 2023 09:44
Is it possible to install the toilet waste pipe with a 90-degree bend?
hanghaus2023
23 May 2023 09:46
Where should it be installed then?
Under the shower is not possible if you prefer a walk-in (curbless) shower.
hanghaus2023
23 May 2023 09:49
Why not reconsider the design from @kbt09 post #34.
hanghaus2023
23 May 2023 10:26
Here is an alternative layout that provides a bit more space for the walk-in closet. Alternatively, a door to the restroom?
Floor plan: Bedroom on the left with double bed, bathroom on the right with bathtub, wooden floor
Stein2023
23 May 2023 10:31
@hanghaus2023 We like your suggestion from post 23 best. It will probably end up being a combined children’s and parents’ bathroom plus an additional storage room for the washing machine and dryer.
