We are almost finished with the planning of our house; only the bathroom layout remains to be finalized.
The bathroom is relatively small and has sloped ceilings, but we would still like to have a walk-in shower if it can be done without major compromises.
The first draft comes from the general contractor’s floor plan, and I tried making a second version myself. My girlfriend has already criticized the second plan because you step directly into the shower when entering the bathroom; maybe this could be changed by having the door open in the opposite direction. I see the main advantage of my layout in the significantly longer shower. The contractor’s shower is about 130cm (51 inches), mine is over 150cm (59 inches).
The room measures approximately 270cm by 290cm (106 by 114 inches), and the skylight faces east. To the left of the bathroom is the staircase, and to the right is the study, with the utility room located below it. Do you have any better ideas?
Thank you
Thank you
We almost exactly followed the version suggested by Jochen for our slightly larger bathroom.
Our dimensions are 3.20 m (10.5 ft) wide and 3.02 m (9.9 ft) deep.
The partition wall at the shower is only half-height (about 1.50 m (5 feet)) and directly behind it is the bathtub. Originally, we planned to add a glass panel up to the ceiling on top of the partition wall, but we decided against it. The toilet in our layout is roughly where your window is located.
Water already splashes up to the door on our side. With 50 cm (20 inches) less space, this will probably be even worse.
For that reason, I would not recommend the walk-in shower option as you have it.
