ᐅ Layout Changes for End-Terrace House from Developer
Created on: 25 Apr 2023 19:30
mayglow
We are currently reviewing whether to make any changes to the standard floor plan from our home builder for our end-of-terrace house. There are stricter guidelines that I’m already sure will disappoint some forum members. Roughly, we’ve been told that exterior walls and the façade, including windows and exterior doors, cannot be altered, and load-bearing walls cannot be moved. This mainly concerns the staircase and stair wall. Most other interior walls, as far as we know, are movable. In principle, we could also move in with the unmodified standard layout, but we do see 1-2 points with potential for improvement (though maybe in the end this just fuels the Spec House Building - Small Changes, Unintended Consequences thread).
I will still fill out the questionnaire, even though most of it cannot be changed for us (in particular Section 1 on the development plan is more the home builder’s area).
Plot size – 207 m² (2,230 sq ft)
Slope – slight incline, I don’t have exact survey data, but we can’t change anything at the house entrances anyway.
Site coverage ratio – 0.4
Floor area ratio – 0.8
Building envelope, building line, and setback – not relevant since we cannot change the external shell
Edge development – not relevant since we cannot change the external shell
Number of parking spaces (already included) – garage plus parking space in front
Number of storeys – 2
Roof type – gable roof
Architectural style –
Orientation – north/south
Maximum heights / limits – not relevant
Other conditions: Hornbeam hedge along the cul-de-sac on our property (on the west side; in the floor plans it appears on the right because they are not north-oriented)
Homeowners’ Requirements
Architectural style, roof type, building type: fixed by the home builder
Basement, floors: usable basement + 2 full stories + converted attic (already determined by the builder)
Number of occupants, ages: currently 2 (31 and 32); planning for 1-2 children
Space needs on ground and upper floors:
Office: family use or home office? Home office, both partly working remotely. Ideally, a separate space for each would be great, but if that’s not possible with potentially 2 children, it’s manageable.
Guest bedrooms per year: about 3-4 times a year
Open or closed layout: medium? Open transition between kitchen and living area is a must, but overall, some walls are okay.
Conservative or modern building style: –
Open kitchen, kitchen island: tends to “not fully closed” (see above), but we don’t necessarily need an island if something else is more practical or cost-effective.
Number of dining seats: for 4 people
Fireplace: no
Music / stereo wall: no
Balcony / roof terrace: no
Garage / carport: garage included
Utility garden / greenhouse: no (maybe a small bed later we’d do ourselves)
Additional wishes / special features / daily routine, also reasons why certain things should or shouldn’t be included:
We are both partly working remotely. Currently, we have an office and a desk in the living room. If possible, I’d prefer not to keep working in the living room. If two adults move in, it’s absolutely no problem; with one child it’s probably still fine, with two children… well, by then things might have changed anyway. I feel we’ll find a solution, and if someone locks themselves away in the 4 m² (43 sq ft) closet on the first floor (where the walls are still adjustable) or gets a desk in the bedroom, that might work.
Basement floor plan of a house with two cellar rooms, corridor and stairs
Ground floor plan with terrace, garage, living room, kitchen and hallway
Upper floor plan showing hallway, bathroom and two children’s bedrooms
Attic floor plan with studio and bedroom, architect’s plan
Site plan of a residential block; red frame marks the plot next to numbers 18–21.
Surroundings: To the south are garages for neighboring terrace houses, then a turning area (end of the cul-de-sac), followed by some individual trees and other detached houses. To the east is our block. Then a few small trees and a railway line (several meters lower). To the west, on our property, there is a city-required hornbeam hedge. We will try to negotiate a passage to the street (for bikes and so on). Since the second escape route on the ground floor is via the terrace, I see some chances, but city officials aren’t always easy.
Planning by:
- Home builder
What do you like especially? Why?
- I see the plan working for us both if the family plan doesn’t happen (then it’s very generous) and with 1-2 children as well.
What don’t you like? Why?
- Ground floor: (main pain point) Entrance is relatively narrow with little cloakroom space. The peninsula kitchen feels too small to work well (and probably requires an expensive extractor in the peninsula). The distance from the sofa to the TV is huge. The basement access is in the living room. We’ll probably manage some kind of furnishing on the ground floor, but right now it doesn’t exactly feel “yes, this is perfect.”
- Upper floor: We’ve debated whether to enlarge the 4 m² (43 sq ft) closet slightly to potentially use it later as an overflow office, but actually we find it as planned not bad at all (and initially more practical).
- Attic: The “landing” could be another possible office space if children come; we considered whether to separate it right away with a wall and door or leave it as shown.
So actually: except for the ground floor, we are quite satisfied; everything else is in the range of “if we want the jack-of-all-trades, maybe some changes could be made – or we keep it as is and see if the need arises.”
If you had to give up something, which details/extensions:
- We can give up: changes to the upper floor and attic
- We cannot give up: at least 1 office
Why is the design as it is now? e.g.
Standard plan from the home builder
I think it’s a solid floor plan for young families, but the ground floor worries me a bit. I feel maybe a different staircase shape would have helped, but as far as I’ve been told, that cannot be changed.
How do we best arrange the ground floor? Should we still make some changes here?
Ideas for potential changes to the ground floor
Maybe reduce the kitchen size and straighten the hallway wall? (We’ve discussed this idea in the kitchen forum but haven’t talked to the planner yet.) The scale is off here (I think my cabinets are too large). The rough structural width in the kitchen at the narrowest point is 248 cm (98 inches), so roughly 240 cm (94 inches) minus about 130 cm (51 inches) for both kitchen sides would leave 110 cm (43 inches) aisle width. Also, the window would be moved to the corner. In return, there would be more cloakroom space in the hallway. Bad idea? Opinions?
2D floor plan of a house with hallway and WC
Another question is a bit… can we reduce the distance between sofa and TV? I’ve just sketched in our current furniture; it would look roughly like this (sofa 275 x 220 cm (108 x 87 inches)).
Floor plan of a room with blue furniture: L-shaped sofa on the right, table in the center, octagonal rug.
Ideas so far include putting a shelf behind the sofa (but that blocks the terrace door more). Any other ideas?
mayglow27 Apr 2023 00:41
I would still include the upper floor in the planning.
What’s the situation with the staircase now? Is it possible to change its position or not?
We haven’t requested that yet; I wanted to discuss it again with my husband first. He says, “asking won’t cost us anything” :p
Meanwhile, I’m thinking about what exactly I want to ask 😉 If there’s a chance, the usual request so far has been for a sketch.
First, regarding the windows, the sketch hasn’t been submitted yet and we’re still considering what exactly to sketch. I currently see the kitchen continuing at the lower end of the plan (although narrower than the original, either as a galley or an L-shape with a door), and I think I don’t want another window in the kitchen area, but I’ll sleep on it 😉 So, for the ground floor, we’re probably at the 11th proposal, I think.
K a t j a schrieb:
Put windows in— as many and as big as you can! Also in the children’s rooms!
I think we would request windows for the children’s rooms as well, although at some point we will have to consider what our budget says about that. But I think windows are more important to us than many other things.
My idea wouldn’t be floor-to-ceiling windows but, if possible, wider than the attic windows. My poor drawing skills produced something like this on the first try:
Floor plan of a single-family house with hallway, bathroom, two children’s rooms, and storage room
Front view of a two-story house with garage, windows, and foundation lines.
(No idea if the heights and widths match up; consider it just a sketch :S)
I’m going to think about whether I find this useful, and if it could work the building technician can decide 😉 Feedback, as always, is welcome.
And then the staircase, phew. Since I’m making half the adjustments here in Paint, umm… generally a challenge?
A spiral staircase is exactly what I see as hitting a dead end here.
Do you mean because of the wall that the staircase meets in the basement? Or the wall next to the staircase on the ground floor?
11ant27 Apr 2023 01:07
mayglow schrieb:
Are you referring to the wall that the staircase leads to in the basement? Or the wall next to the staircase on the ground floor?
Neither. It’s about 3 out of 120 staircases for which a completely different design would need to be built. And that even if the turn was switched to only one side on the winding stairs and the landing was kept. A custom logistics challenge par excellence.
Take a look at the reference projects where this house type is already occupied, and talk to the buyers there.
By the way, what does the "HFH (A)" on the party wall mean?
mayglow27 Apr 2023 01:39
Neither. Because of the 3 out of 120 steps, for which a completely different shape would have to be built.
Makes sense, then maybe I’ll just ask a general question first before I waste more time leveling up my Paint skills 😉
Although I don’t think my first attempt looked too bad :P
Floor plan: stairs on the left, door bottom right, living/cooking/dining area 42.13 m²
What does the "HFH (A)" on the separating wall between houses mean?
No idea. It’s marked like that on all the dividing walls in the row house block (the plan covers the entire block). A quick search suggests HFH might stand for highly fire-resistant, and also that "According to the 2002 Model Building Code (MBO), row house dividing walls must be at least highly fire-resistant, e.g. F 60-A or REI 60." So that could fit?
mayglow27 Apr 2023 01:52
By the way, we also once considered extending the wall in front of the stairs to create a small storage closet. But with a width of only 95cm (37 inches), the usefulness would be limited. The main idea was to reduce the distance between the sofa and the TV, which is important for me as someone with limited vision. However, I don’t really like it in the living room either, because then it would extend up to the patio door.
2D floor plan with stairs, walls, and archway, architectural drawing
something like this
But probably a similar effect could be achieved with furniture arrangements if desired, and the sofa doesn’t necessarily have to be pushed all the way against the wall.
kbt09
27 Apr 2023 07:26
mayglow schrieb:
I currently see the kitchen further down the plan (though narrower than the original, either as a double-row or L-shape with a door), and I think I don’t want another window in the kitchen area, but I’ll reconsider.
As a fan of the terrace kitchen 😉 I tend to agree with you there. I would plan the kitchen width at about 247/248 cm (97–98 inches). That basically gives you the option for either a double-row layout or possibly a U-shape. Because of the window arrangement, I would always plan the tall cabinets on the right side of the plan so that the window along the bottom remains fully visible. On the right side of the plan, as previously suggested, I would add a window. If desired, it could be floor-to-ceiling, but I would probably go with a window sill height.
I still find the basement stairway very disruptive. Generally, I would prefer to place the sofa on the left side of the plan so that there’s more open space to the right side, toward the kitchen and dining area, preventing the room from feeling cramped and divided into three tight sections.
In other words, I would definitely try to keep the stair direction the same but rotate the basement door by 90 degrees. Changing the stair direction itself doesn’t help much because you still need the space currently used by the basement door to enter the stairs.
F
Fuchsbau35
27 Apr 2023 07:52
I don’t know if this has already been mentioned, but the guest toilet door and the front door could collide awkwardly if the former is left open wider than shown. Moving the guest toilet door hinge to the right would be one option, or using a sliding door.
