ᐅ Layout Changes for End-Terrace House from Developer
Created on: 25 Apr 2023 19:30
mayglow
We are currently reviewing whether to make any changes to the standard floor plan from our home builder for our end-of-terrace house. There are stricter guidelines that I’m already sure will disappoint some forum members. Roughly, we’ve been told that exterior walls and the façade, including windows and exterior doors, cannot be altered, and load-bearing walls cannot be moved. This mainly concerns the staircase and stair wall. Most other interior walls, as far as we know, are movable. In principle, we could also move in with the unmodified standard layout, but we do see 1-2 points with potential for improvement (though maybe in the end this just fuels the Spec House Building - Small Changes, Unintended Consequences thread).
I will still fill out the questionnaire, even though most of it cannot be changed for us (in particular Section 1 on the development plan is more the home builder’s area).
Plot size – 207 m² (2,230 sq ft)
Slope – slight incline, I don’t have exact survey data, but we can’t change anything at the house entrances anyway.
Site coverage ratio – 0.4
Floor area ratio – 0.8
Building envelope, building line, and setback – not relevant since we cannot change the external shell
Edge development – not relevant since we cannot change the external shell
Number of parking spaces (already included) – garage plus parking space in front
Number of storeys – 2
Roof type – gable roof
Architectural style –
Orientation – north/south
Maximum heights / limits – not relevant
Other conditions: Hornbeam hedge along the cul-de-sac on our property (on the west side; in the floor plans it appears on the right because they are not north-oriented)
Homeowners’ Requirements
Architectural style, roof type, building type: fixed by the home builder
Basement, floors: usable basement + 2 full stories + converted attic (already determined by the builder)
Number of occupants, ages: currently 2 (31 and 32); planning for 1-2 children
Space needs on ground and upper floors:
Office: family use or home office? Home office, both partly working remotely. Ideally, a separate space for each would be great, but if that’s not possible with potentially 2 children, it’s manageable.
Guest bedrooms per year: about 3-4 times a year
Open or closed layout: medium? Open transition between kitchen and living area is a must, but overall, some walls are okay.
Conservative or modern building style: –
Open kitchen, kitchen island: tends to “not fully closed” (see above), but we don’t necessarily need an island if something else is more practical or cost-effective.
Number of dining seats: for 4 people
Fireplace: no
Music / stereo wall: no
Balcony / roof terrace: no
Garage / carport: garage included
Utility garden / greenhouse: no (maybe a small bed later we’d do ourselves)
Additional wishes / special features / daily routine, also reasons why certain things should or shouldn’t be included:
We are both partly working remotely. Currently, we have an office and a desk in the living room. If possible, I’d prefer not to keep working in the living room. If two adults move in, it’s absolutely no problem; with one child it’s probably still fine, with two children… well, by then things might have changed anyway. I feel we’ll find a solution, and if someone locks themselves away in the 4 m² (43 sq ft) closet on the first floor (where the walls are still adjustable) or gets a desk in the bedroom, that might work.
Basement floor plan of a house with two cellar rooms, corridor and stairs
Ground floor plan with terrace, garage, living room, kitchen and hallway
Upper floor plan showing hallway, bathroom and two children’s bedrooms
Attic floor plan with studio and bedroom, architect’s plan
Site plan of a residential block; red frame marks the plot next to numbers 18–21.
Surroundings: To the south are garages for neighboring terrace houses, then a turning area (end of the cul-de-sac), followed by some individual trees and other detached houses. To the east is our block. Then a few small trees and a railway line (several meters lower). To the west, on our property, there is a city-required hornbeam hedge. We will try to negotiate a passage to the street (for bikes and so on). Since the second escape route on the ground floor is via the terrace, I see some chances, but city officials aren’t always easy.
Planning by:
- Home builder
What do you like especially? Why?
- I see the plan working for us both if the family plan doesn’t happen (then it’s very generous) and with 1-2 children as well.
What don’t you like? Why?
- Ground floor: (main pain point) Entrance is relatively narrow with little cloakroom space. The peninsula kitchen feels too small to work well (and probably requires an expensive extractor in the peninsula). The distance from the sofa to the TV is huge. The basement access is in the living room. We’ll probably manage some kind of furnishing on the ground floor, but right now it doesn’t exactly feel “yes, this is perfect.”
- Upper floor: We’ve debated whether to enlarge the 4 m² (43 sq ft) closet slightly to potentially use it later as an overflow office, but actually we find it as planned not bad at all (and initially more practical).
- Attic: The “landing” could be another possible office space if children come; we considered whether to separate it right away with a wall and door or leave it as shown.
So actually: except for the ground floor, we are quite satisfied; everything else is in the range of “if we want the jack-of-all-trades, maybe some changes could be made – or we keep it as is and see if the need arises.”
If you had to give up something, which details/extensions:
- We can give up: changes to the upper floor and attic
- We cannot give up: at least 1 office
Why is the design as it is now? e.g.
Standard plan from the home builder
I think it’s a solid floor plan for young families, but the ground floor worries me a bit. I feel maybe a different staircase shape would have helped, but as far as I’ve been told, that cannot be changed.
How do we best arrange the ground floor? Should we still make some changes here?
Ideas for potential changes to the ground floor
Maybe reduce the kitchen size and straighten the hallway wall? (We’ve discussed this idea in the kitchen forum but haven’t talked to the planner yet.) The scale is off here (I think my cabinets are too large). The rough structural width in the kitchen at the narrowest point is 248 cm (98 inches), so roughly 240 cm (94 inches) minus about 130 cm (51 inches) for both kitchen sides would leave 110 cm (43 inches) aisle width. Also, the window would be moved to the corner. In return, there would be more cloakroom space in the hallway. Bad idea? Opinions?
2D floor plan of a house with hallway and WC
Another question is a bit… can we reduce the distance between sofa and TV? I’ve just sketched in our current furniture; it would look roughly like this (sofa 275 x 220 cm (108 x 87 inches)).
Floor plan of a room with blue furniture: L-shaped sofa on the right, table in the center, octagonal rug.
Ideas so far include putting a shelf behind the sofa (but that blocks the terrace door more). Any other ideas?
27 Apr 2023 07:53
Buyers, who actually would have preferred to be the builders, honestly cause “problems” with their unrealistic dream house ideas.
Nope. After several years in the forum, nothing surprises me anymore. The focus is on the straight staircase; then you're trendy, and the children’s rooms have to take a back seat.
mayglow schrieb:
I’m currently trying to figure out what exactly I want to ask 😉
Probably my point about the staircase and the upper floor: I tend to see the rooms arranged horizontally, with the bathroom opposite the staircase featuring a west-facing window. This can then be nicely aligned visually with the ground floor west door, creating a cohesive line.
kbt09 schrieb:
Because I would generally prefer to place the sofa on the left side of the plan, so that the right side towards the kitchen and dining area feels more spacious and the room doesn’t look divided into three tight sections.
Me too!
kbt09
27 Apr 2023 08:04
Probably my concern about the staircase and the upper floor: I rather see the rooms arranged across and the bathroom opposite the staircase with a west-facing window. This can be visually coordinated nicely with the ground floor west door and aligned accordingly.
I also think that's a good idea... it’s another point in favor of the staircase with the turn at the stair exit 😉
mayglow27 Apr 2023 09:04
I actually see the rooms arranged horizontally, with the bathroom opposite the stairs featuring a west-facing window.
I think that goes beyond what we would be willing to change. That would mean completely redesigning the upper floor, bathrooms would no longer be stacked, and so on. We would be deviating entirely from the standard with a full custom plan. I believe these are can of worms we prefer not to open. Honestly, I don’t find the upper floor that bad either 😉
27 Apr 2023 10:52
mayglow schrieb:
I believe those are barrels; we won’t be opening them.
Ok, that’s a statement we can work with!
Now it’s about minor details, possibly a rough kitchen layout, where to place tall cabinets in case an additional window is needed, if a patio door near the garage isn’t enough. I think a patio door in the dining area can bring in a lot of light.
11ant27 Apr 2023 12:17
I tend to arrange the rooms horizontally, with the bathroom opposite the stairs and a west-facing window.
That’s quite an effort from a logistics perspective, but a charming idea. Maybe @goalkeeper also has an opinion on this house; after all, they shouldn’t only be the target of silly neighbors and incompetent local officials (although, even adding a dormer for the bedroom would probably exceed the scope for custom requests here).
mayglow27 Apr 2023 16:17
Possibly a rough kitchen layout showing where tall cabinets could go for a potential additional window
We also had a thread about this in the specialist forum, and the recommendation was quite unanimous for the suggestion:
Floor plan of a house with walls, doors, stairs, and room layout.
Probably with a door opening into the hallway or a sliding door or something similar. (My husband is currently very attached to the idea of an extra door, but I don’t see it as absolutely necessary. However, he definitely has the final say in the kitchen since he is the main user.)
My objections that the window would then be partly blocked by the tall cabinets weren’t seen as a big issue by anyone. And my proposals for a U-shaped or two-line layout got absolutely zero supporters.
Right now, my husband and I prefer, instead of three tall cabinets, to just have the refrigerator and next to it a base wall cabinet and upper wall cabinet area as a coffee corner, roughly something like this:
Top-down floor plan of an open kitchen with countertops, stove, and wood flooring.
Again, everyone else thought that was a bad idea, but in the end, we have to live with it 😉
So far, we haven’t been to the kitchen showroom yet; that’s scheduled for next Saturday. Maybe there will be new inspiration there.
