Created on: 27 May 2019 10:48
goalkeeper
apokolok schrieb:
Who here has ever replaced media cables? A conduit that doesn’t allow for cable replacement or expansion has failed its purpose and is basically just a protective sleeve. Especially in residential settings, with heavy video content and other entertainment, data rates are increasing and protocols are changing faster than in office communication. In such cases, it’s almost pointless to install cables if, ten years later, you’ve already jumped three generations ahead and end up “laying wireless cables alongside” because the physical connections are too slow—while the empty conduits refuse to allow pulling out the old cables or installing additional ones. You can’t seriously promote terabit speeds while relying on outdated wiring.
goalkeeper27 Jan 2020 23:24But seriously, of course you want to be future-proof. However, this will certainly depend on
What about the marked location? It would probably be the least obtrusive there.
How often do you need to access the outdoor unit?
Scout schrieb:
The windows on the upper floor garden side have a sill height of 100 cm (39 inches). The outdoor unit could still fit underneath. Or possibly in the attic if it is outside the thermal envelope.
goalkeeper28 Jan 2020 07:04Scout schrieb:
Every one or two years. But isn’t the open outside already limiting the building plot? No – the building plot is only limited at the front by the first 2.50m (8 feet). Other than that, I can do whatever I want.
That would fit nicely behind the parking space. In summer, when you’re sitting on the terrace, the heat pump only kicks in occasionally for hot water, and in winter, you probably spend very little time outside. The bicycle parking spots would also work well in the front garden, in front of the bathroom window.
goalkeeper28 Jan 2020 07:16Scout schrieb:
then that would work, just behind the parking space. In summer, when you’re sitting on the terrace, the heat pump only turns on occasionally for hot water, and in winter you probably rarely sit outside anyway. The bicycle parking spaces would also fit well in the front garden, in front of the bathroom window. Please take another close look at the picture – I have marked an alternative location with a red cross.
The current location was already planned this way in the building permit / planning permission. However, it takes up space we could use for a garden shed.
