Created on: 27 May 2019 10:48
goalkeeper
goalkeeper27 Jan 2020 11:4011ant schrieb:
Did the smart aleck ever explain where conduit pipes are actually used or why they are called that in his opinion?They serve as mechanical protection for the cables laid on the floor during the construction phase—hence the term conduit.
Has the smart guy ever explained why conduit pipes are actually used, or why they are called that in his opinion? In everyday language, they are called "conduit pipes," but electricians differentiate between the regular conduit pipe, which must allow for the cables inside to be replaced, and the protective sleeve. The latter is intended to protect cables during construction or when installed in concrete slabs.
goalkeeper schrieb:
Of course, the outdoor unit of the air-to-water heat pump is not considered an auxiliary installation. It is part of the building and therefore must be included within the building plot.Do you still have any "building plot" left anywhere at all?G
goalkeeper27 Jan 2020 12:28kaho674 schrieb:
Do you still have any "building plot" left at all?Yes, of course. Only the first 2.50 m (8 feet) at the front must remain undeveloped. The rest can be built on.
Scout schrieb:
In everyday language, the term "empty conduit" is used, but electricians distinguish between common empty conduits, which must allow their contents to be replaced, and protective conduits. The latter are intended to protect cables during the construction phase or when installed in concrete slabs. Then he should say it like that – and not assume on his own that when the client wants empty conduits, they actually mean only protective conduits, leading to reopening everything for the smallest changes.
