Created on: 27 May 2019 10:48
goalkeeper
goalkeeper
27 May 2019 10:48
goalkeeper
3 Jun 2019 12:19
Today we unfortunately learned that our middle terrace neighbor will not be purchasing the plot after all – too many compromises.
He wanted to build with a basement, while we planned a slab-on-grade foundation. However, since we are starting first, there is a rule in Baden-Württemberg granting the neighbor the right to require us to install deeper foundations at our expense, which technically would have been the ideal and “cheapest” solution—if you can call around €15,000 (about $16,000) cheap.
Now we are wondering what will happen if the new middle terrace neighbor is only found after our construction has begun. On one hand, underpinning is always significantly more expensive and, according to our construction supervisor, not ideal because different soil types would then be present, causing the slab foundation to settle unevenly. This could eventually cause our house to lean slightly.
Does anyone know for sure whether in Baden-Württemberg one must always agree to underpinning?
Z
Zaba12
3 Jun 2019 12:35
Sounds interesting. I'll subscribe to you.
goalkeeper
3 Jun 2019 13:46
I would prefer something more relaxing...
Z
Zaba12
3 Jun 2019 14:41
goalkeeper schrieb:
However, it was finally agreed that the group of houses will be built with a gable roof with a pitch between 35° and 40°. There is some flexibility within these 5 degrees.
How is that supposed to work? Are the houses staggered? If not, wouldn’t that look odd?
The local council really caused you trouble here. Many have already mentioned it, but this type of construction is really suited for a developer.
Escroda
3 Jun 2019 14:55
goalkeeper schrieb:
Does anyone know for sure whether foundation underpinning always requires consent in Baden-Württemberg?
You already quoted the Neighbor Law in your other thread, which states that consent must be given. There might even be a special circumstance where underpinning could be prevented, but I have no idea what that could be. That would also be a very significant interference with the neighbor’s property rights.
