Created on: 27 May 2019 10:48
goalkeeper
apokolok schrieb:
Is it possible to omit the stud wall behind the washbasin entirely?
The pipes should also be able to be installed inside the wall. As far as I remember, this is only a 10 cm (4 inches) interior wall made of sand-lime brick – chasing it horizontally for a 50 mm (2 inches) drainage pipe would be crazy.
pffreestyler10 Jan 2020 11:09Can't you build the stud wall yourself? Materials might cost around 40 euros and it takes about 1-2 hours. It's really easy, even for those with less experience in DIY. You'll get a nice hourly rate out of it.
Scout schrieb:
That is just a 10cm (5 inches) interior wall made of sand-lime brick, as far as I remember – chasing it horizontally for a 50mm (2 inches) drain pipe would be crazy.On the contrary, since it is probably non-load-bearing at that thickness. Instead of chasing, you would make a recess. The pipe goes directly into the wall. Wrap it with insulation wool if desired, then apply reinforcing mesh and plaster over it.
With a 50 mm (2 inch) pipe plus an additional 10 mm (0.4 inch) for installation, only 40 mm (1.6 inch) of wall thickness remains over a length of about two meters. Since the wall is presumably already built, creating a recess at this stage is out of the question. So, the wall chaser would have to be used... which means the upper two meters of sand-lime brick will rest on a 40 mm (1.6 inch) thick base... no thanks!
Furthermore, when pipes are installed flush within walls, the absence of impact sound insulation, such as proper pipe casing, can result in the transmission of installation noise to the wall and into adjacent rooms where noise protection is important. If a completely impact-sound-free flush installation of pipes cannot be guaranteed, it is recommended to install pipes in front of the wall.
If it is done this way, the tradesperson will rightly raise their concerns in writing.
