Created on: 27 May 2019 10:48
goalkeeper
Wow, those boxes are quite expensive.
The access points don’t necessarily have to be mounted on the ceiling in the hallway.
If the appearance bothers you, just place the one on the ground floor inside the TV cabinet or something similar; the attic is also fine, since they probably won’t be installing a concrete ceiling up there.
goalkeeper schrieb:
You’re probably right about that. However, there is an additional cost of 120–150 € per LAN outlet.How about - 1 LAN outlet in the living room for the FritzBox
- 1 LAN outlet in the hallway on the upper floor for the access point
- and one empty conduit each in the basement and attic
For the last two, a cable for the access point will be added if needed(!).
There is no basement. Conduit would of course be possible.
LAN connections will be added anyway; this was only about additional outlets, for example in the hallway for an access point.
I wouldn’t start using the Fritzbox Wi-Fi just to avoid having an access point.
If multiple access points are necessary, they should be compatible, meaning for example all from Ubiquiti.
The modem/router also doesn’t have to be located in the living room but can be placed in the utility room or wherever it won’t be intrusive.
goalkeeper8 Jan 2020 14:21I would place the router near the patch panel. It will most likely be in the utility room in the attic - more details will be clarified tomorrow.
Unfortunately, iPhones no longer have a direct network port, so I also have to use the "detour" via Wi-Fi in the bedroom.
You can also stream Netflix over LAN in the bedroom.
If you’re building without a basement and the utility room (HAR) in the attic: Install an access point in the hallway on the ground floor and place the FritzBox in the utility room (you can always add another access point later if needed). For the upper floor, I’d initially just lay an empty conduit to the hallway there, and if necessary, you can add a second or third access point. Depending on the signal reception, you’ll then be able to determine whether an additional access point is worthwhile.
goalkeeper schrieb:
Unfortunately, iPhones no longer have a direct network connection,The wives I know don’t watch their Rosamunde Pilcher series on tablets or even smaller screens.https://www.instagram.com/11antgmxde/
