Created on: 27 May 2019 10:48
goalkeeper
goalkeeper8 Jan 2020 16:29Domski schrieb:
If the appearance bothers you, install an empty junction box, coil the LAN cable inside, and cover it with a blank cover that you can paint over. My concern is the look of the access points: in the small hallway, I would have a ceiling light, an access point, and a smoke detector on the ceiling. Not exactly a nice sight.
Don’t you have a niche in the hallway where a floor-to-ceiling built-in wardrobe could fit? Behind it on the wall, you could have a flush-mounted box with the cable, placing the access point inside the wardrobe itself (or on top of it if necessary).
A lamp can be a decorative element that shapes the space, while the smoke detector is, well, just a technical necessity...
goalkeeper8 Jan 2020 16:52Scout schrieb:
Don't you have a recess in the hallway where a floor-to-ceiling built-in closet would fit? You could install an in-wall junction box with the cable behind it, and place the access point inside the closet (or on top if necessary).We have a coat closet on the ground floor, so that would work there. But not on the upper floor and attic, since it’s an end-of-terrace house. The hallways there are quite wide.
goalkeeper schrieb:
I’m concerned about the appearance of the access points: in the small hallway, I would have a ceiling lamp, access point, and smoke detector all on the ceiling. Not exactly attractive. Then just use, for example, the Unifi In-Wall Access Point and place it as high as possible on the wall. If the Wi-Fi quality is good, don’t put a cabinet in front of the access point, let alone inside a cabinet.
Definitely prepare for one access point on each floor. I find it even more important in a townhouse than in a detached house. If your new neighbor gets the brilliant idea to install a router or access point on the wall facing you, they will saturate the 2.4 GHz band, making you grateful for any access point that still transmits well on 5 GHz.
goalkeeper9 Jan 2020 23:37We have now positioned all access points at appropriate locations in the hallways. Unifi or TP-Link offer slim wall-mounted access points. That will work well. Thanks @hanse987
Regarding plumbing, we are uncertain about one thing: the toilet and the washbasin are next to each other. The plumber would build the wall frame for the washbasin with a depth of about 10cm (4 inches) and the one for the toilet with 20cm (8 inches). The shallower frame for the washbasin gives us more space between the countertop and the opposite wall of the walk-in shower.
Has anyone had a similar setup and can share a photo?
