Hello everyone!
I am looking for specific recommendations for a home network where 2 access points will be powered via PoE.
Each room will have a double LAN outlet, which will then be connected to a patch panel.
However, I want to have 2 wall or ceiling outlets installed to provide Wi-Fi coverage for the ground floor and the upper floor.
Do you have specific recommendations for a PoE-capable switch and access points that perform well?
O
Obstlerbaum21 Feb 2019 14:56I use TP-Link (access point & PoE switch), everything runs smoothly. But honestly: manufacturers don’t differ that much. Sometimes there are issues with the details if you want advanced features. Access points and switches can also be from different manufacturers—that’s why standards exist. After all, your power outlet for the TV isn’t from Samsung/LG/Sony either...
For the access points, I would also recommend UniFi. I’m currently using the AC-Lite model, which is sufficient for me, but of course, higher-end models are even better.
How many PoE devices are there in the entire network? If there are only two devices, I would use the included injectors. For more PoE devices, I would choose a PoE-capable switch with just over the number of required ports, and use a regular switch for the rest. I like the devices from Zyxel’s GS1900 series, but many other manufacturers also offer good options.
