Created on: 27 May 2019 10:48
goalkeeper
goalkeeper
11 Feb 2020 10:06
We will have the painting work done by the general contractor (GC) – otherwise, we will install the Parador Modular One design floor throughout the entire house, except of course in the wet areas. Those will be tiled.
The flooring is installed like laminate and only requires a vapor barrier underneath – it already includes impact sound insulation and more. That is about 100 sq meters (1,076 sq feet) to be installed by two people. I think it should be possible to complete within a week.
halmi
11 Feb 2020 10:17
If you have good endurance, you might manage two full days in a row, but then your knees and the skin will be completely worn out, and you’ll need to take at least two days off. We have now installed nearly 75m² (800 sq ft) over three weekends, working 2-3 hours on Fridays and 6-8 hours on Saturdays, which worked quite well.
The flooring was solid vinyl and could easily be scored and snapped with a knife, which is much simpler and faster than cutting each plank with a jigsaw or miter saw.
goalkeeper
11 Feb 2020 10:24
kaho674 schrieb:
Cost?
22-25 € per sqm (square meter).
MayrCh
11 Feb 2020 10:24
goalkeeper schrieb:
That amounts to about 100 sqm (1,076 sq ft) for two people.
100 sqm (1,076 sq ft) in one go is not the problem. However, divided into 4 to 5 rooms, it will take longer because the first row has to be installed perfectly; otherwise, it will look chaotic.
If you’ve already installed flooring, you have the technique, but if not, you’ll need a lot of strength. Lateral epicondylitis (tennis elbow) is common—I dealt with it for about 9 months. Cutting with a jigsaw and circular saw is not difficult, but it creates dust and takes time. Especially in small rooms, it’s a real challenge to mark every 2-3 planks, stand up, go to the miter saw or jigsaw, and then get back on the floor.
goalkeeper
11 Feb 2020 10:27
MayrCh schrieb:
100 sqm (1,076 sq ft) in one piece is not a problem. However, divided into 4 to 5 rooms, it will take longer because the first row has to be laid perfectly; otherwise, it will look messy.
If you have laid flooring before, you already know the technique; if not, you will have to put in a lot of effort. Lateral epicondylitis can be a concern—I dealt with it for about nine months. Cutting with a jigsaw and circular saw is not complicated but creates dust and takes time. Especially in small rooms, it’s quite a hassle to mark every 2-3 planks, get up, go to the miter saw or jigsaw, then go back down to the floor.
My brother-in-law has laid floors several times. He will help me so that one of us lays the floor while the other one does the cutting. That’s basically the plan.
halmi
11 Feb 2020 11:16
I also requested quotes for the installation, which ranged between 32 and 34 hours, complete and finished including baseboards. Don't underestimate the time required and avoid planning too tightly.
Especially the hallway with the staircase and 4-5 rooms consumes an incredible amount of time. Just deciding where to start here took almost 2 hours on its own.
