Created on: 27 May 2019 10:48
goalkeeper
Z
Zaba12
14 Jan 2020 12:05
goalkeeper schrieb:
The plan is to pave around the front and sides of the house and, at least in the garden, to spread out 120 cubic meters (4,238 cubic feet) of soil so it can settle. My wife said I could do it with a shovel.
Then let your wife start—when she loses interest after about half a cubic meter (18 cubic feet), remind her of her statement.
Climbee14 Jan 2020 12:26
goalkeeper schrieb:
Have you ever lived directly under the roof? In our current rented apartment, it gets over 30°C (86°F) in the summer—even at night. Our new house faces west, has 2m (6.5 ft) wide windows, and the living space is in the attic. Therefore, the cooling system will also run in night mode during the peak summer nights.
The new houses are well insulated—both ways. Our bedroom is under the roof (top floor), on the southwest side (the upper left window in my avatar). Before we installed shading this summer, the house felt like a sauna. But as soon as the roller blinds were fitted, the indoor temperature dropped (even though the house had been heated up for weeks beforehand), and the bedroom became comfortably cool for sleeping. I am confident that this year, if shading is consistently applied from the start and the house doesn’t heat up in the first place, it will feel even more comfortable.
With shading, we experienced pleasant indoor temperatures even during this year’s extreme heat. At night, we let the cool air in, then close the windows and lower the blinds. We never had temperatures over 26°C (79°F) anywhere in the house, even though, as mentioned, it was very hot beforehand.
A gentler cooling method involves chilled water pipes arranged in spirals within the ceiling. However, that’s probably too late for you. They cool the ceiling to the temperature of the chilled water, causing the cooler air to sink. This provides about 5°C (9°F) of cooling without any drafts. It should be more than enough for the new houses.
goalkeeper
14 Jan 2020 13:09
We are getting an air-to-water heat pump that also has a cooling function through the underfloor heating system. However, our general contractor still recommends adding an air conditioning unit.
boxandroof
14 Jan 2020 13:18
How is the roof insulated?
kaho67414 Jan 2020 13:23
I regularly catch colds from air conditioners. That’s why I’m glad we use gentle cooling through a geothermal heat pump. But under the roof, that might not be enough – that’s possible. In any case, I would recommend placing the unit as far away from the bed as possible.
goalkeeper
14 Jan 2020 13:26
240mm (9.5 inches) insulation batts
