V
valentin4424 Jul 2022 19:07Hello everyone,
I am planning to upgrade my IKEA Besta furniture and wonder which surface treatment would be best suited for this. The Besta units usually have a relatively thin melamine coating, which is durable but doesn’t always hold up well against some wear and moisture.
I am particularly interested in methods that reliably protect against scratches, improve the appearance, and are not too complicated to apply. I am thinking, for example, about applying a paint or clear coat sealant afterwards, using a film, a wax layer, or even oiling the wood—if that makes sense at all with these mostly coated surfaces.
Do you have any experience or recommendations on the best surface treatment for IKEA Besta? Suggestions regarding products, application tips, or potential risks—such as the surface peeling off or becoming unattractive—are also welcome. Thanks in advance for your helpful answers!
Hello valentin44,
In general, caution is advised with IKEA BESTA furniture due to the melamine coating. The material underneath is usually particleboard or MDF, so the surface cannot be sanded or oiled like solid wood.
I recommend sealing with a clear varnish if you are looking for scratch protection. Make sure the varnish is specifically designed for coated surfaces, as otherwise adhesion problems may occur. Alternatively, high-quality self-adhesive films can be helpful since they provide protection and can offer different looks without damaging the original.
I consider a wax layer less suitable because wax often does not adhere well to melamine and does not provide lasting protection.
If you want to preserve the original appearance, clear varnish or film are therefore the best options.
Emery schrieb:
I recommend sealing with clear varnish if you are looking for scratch protection.I think clear varnish sounds reasonable, but who wants to spend hours brushing varnish onto a piece of furniture? Besides, why apply anything at all when you can’t easily finish IKEA’s inexpensive melamine surface like real wood?
It’s really a trade-off between effort and benefit – I would rather use a water-repellent film. It’s quick to apply, provides protection, and at the same time offers design options with patterns or colors.
Let’s be honest: who needs professional sealing on an inexpensive piece of furniture?
Hello valentin44,
I would like to add that the condition of your furniture and its intended use are crucial. For light to moderate use, a high-quality transparent matte film is very effective. It protects against scratches and moisture and can be easily replaced if needed.
If you choose paint, make sure to apply the appropriate primer. Without it, the paint will not adhere properly, and you risk blistering or peeling. Additionally, the treatment should be applied in several thin layers to achieve a uniform finish.
Wax is hardly recommended as protection for this type of surface because it does not penetrate deeply and is removed quickly.
In general, if you want to protect the surface permanently, film and clear-coated layers are the best options, depending on the effort involved and your aesthetic preferences.
Lamar schrieb:
Let's be honest: Who needs professional sealing on an inexpensive piece of furniture?I think this view is too limited. Just because the price is low doesn’t mean the surface quality should be underestimated. While the internal structure may be inexpensive, the surface is in direct visual and functional contact and significantly affects the furniture’s lifespan.
For me, proper surface treatment also involves considering long-term use. If you only use a simple laminate or foil, the furniture might wear out quickly and lose its aesthetic appeal.
Additionally, we should always keep environmental aspects in mind when making recommendations: What are the ingredients in paints or coatings? How sustainable are laminate products?
In my opinion, this topic always requires a nuanced assessment of materials and sustainability, not just quick protection through a foil layer.
