I am planning to upgrade my IKEA Besta furniture and wonder which surface treatment would be best suited for this. The Besta units usually have a relatively thin melamine coating, which is durable but doesn’t always hold up well against some wear and moisture.
I am particularly interested in methods that reliably protect against scratches, improve the appearance, and are not too complicated to apply. I am thinking, for example, about applying a paint or clear coat sealant afterwards, using a film, a wax layer, or even oiling the wood—if that makes sense at all with these mostly coated surfaces.
Do you have any experience or recommendations on the best surface treatment for IKEA Besta? Suggestions regarding products, application tips, or potential risks—such as the surface peeling off or becoming unattractive—are also welcome. Thanks in advance for your helpful answers!
Here is a structured overview of surface treatment for IKEA Besta:
- Material: Melamine coating on MDF/particleboard
- Sanding: not possible without damage
- Oiling: not suitable, as the surface is sealed and oil does not penetrate
- Waxing: offers limited protection, poor adhesion on melamine
- Clear lacquer: possible, but only with a suitable primer and patience during application
- Films: quick, reversible, visually flexible
Tip: If using lacquer, always test a small area first. Some clear lacquers may yellow slightly or not adhere permanently to the melamine surface. Film is usually the risk-free option.
Avoid mistakes:
- Do not use aggressive cleaners before treatment
- Do not use very coarse sandpaper
- Apply lacquer in well-ventilated rooms
In summary, self-adhesive films are best for beginners, while lacquer requires more effort and experience.
Avoid mistakes:
tolokau schrieb:
Tip: If using paint, always test a small area first.This is a really important tip.
Additionally, I would add that using a polyurethane-based clear coat is usually safer than opting for cheaper acrylic paints, which tend to be less durable.
A question for everyone: What about the environmental impact of the different products? Are there any recommended, more environmentally friendly options or alternatives?
I think this is a relevant aspect that is often overlooked, especially with traditional paints and films.
Danial schrieb:
Are there any recommended, more environmentally friendly options or alternatives?There are some ecological sheet products available, but they are usually more expensive.
Otherwise, the most environmentally friendly approach is to treat furniture minimally and replace or repair parts only when necessary.
It is true that many paints contain a significant amount of solvents.
