ᐅ How can I equip Ikea Besta units with custom-made handles?
Created on: 6 Sep 2021 16:47
mahmood
mahmood
6 Sep 2021 16:47
Hello everyone, I bought an Ikea Besta shelf unit and would like to equip it with custom-made handles because I don't like the standard handles and want to give the furniture a more personal touch. My idea is that the handles should not only look good but also feel comfortable to hold and be durable, as the shelf is used daily. Does anyone have experience with the best way to attach such custom handles? Are there specific materials that work particularly well, and what should I be careful about when drilling or fastening to avoid damaging the shelf? I would really appreciate any tips and suggestions!
sihau
6 Sep 2021 17:05
As a general recommendation, measure the thickness of the shelves and back panels carefully before drilling. For DIY handles, materials like wood or metal are suitable because they are easy to work with and durable. If you make handles from wood, be sure to sand the surface well and ideally seal it with a protective finish to ensure longevity. The attachment is usually done with screws inserted from the inside through the front, so you will need screws of the appropriate length—not too long. Make sure the drill holes are precisely aligned with the handle mounting points; otherwise, the shelf could be damaged, or the handles may not be securely fixed.
Lotizar
6 Sep 2021 17:23
In addition to sihaus’s tips: Most Besta doors or drawers come with pre-drilled holes for handles. You can use these or drill new holes if you want to place the handles in a different position. If you are making your own handles, it is recommended to use threaded rods or metal bolts as connecting elements because they allow for easy adjustment. It is also important to use a drill with a depth stop to avoid damaging the back panel or the interior. A tip: if you are making wooden handles, a router makes it easier to create rounded or ergonomic edges than just using sandpaper.
bente
6 Sep 2021 18:02
I think it’s great that you want to personalize the shelf! Often, furniture pieces are so standardized. I myself added handles made of thick leather to a similar shelf, which worked very well and gives it a warm look. You do need sturdy screws and possibly washers to prevent the leather from being pressed in. At first, I wasn’t sure if the leather handles would hold, but I have been using the shelf for almost a year now without any issues. If you like, I can gladly explain how I cut and attached the leather pieces.
TANNAU
6 Sep 2021 18:15
Drill holes should be measured precisely; it is best to create a template. Materials: wood and metal are sturdy. Secure screws from the inside. Protective coating for wooden handles is recommended. Choose a drill bit that matches the hole size.
Genevieve
6 Sep 2021 19:03
I question the general assumption that homemade handles always offer better aesthetics or functionality. It is important to carefully consider whether the production costs and effort are justified by the benefits. Especially with Ikea Besta, which is a relatively affordable piece of furniture, elaborate handles might unnecessarily alter its practical character. However, if you are aiming for a high design value, it can be worthwhile. I would also be interested in knowing what type of “homemade handles” are specifically meant: wood, metal, leather, fabric, or perhaps even upcycled materials? Depending on the choice, there are different advantages and disadvantages regarding durability, maintenance, and cost.
