ᐅ Is there a guide for assembling IKEA Besta without using any tools?
Created on: 20 Jan 2024 14:07
mansi
mansi
20 Jan 2024 14:07
I am planning to assemble an IKEA Besta shelving unit, but I was wondering: is there even a clear and reliable guide on how to build the Besta unit completely without using any tools?
I understand that usually screwdrivers or Allen wrenches are needed, but I am looking for a method that requires no tools at all – maybe with clever techniques, click systems, or alternatives that make assembly easier.
Has anyone ever tried something like this or knows a practical solution where no tools are actually necessary?
Thanks for any helpful tips!
dijan
20 Jan 2024 14:21
mansi schrieb:
Is there any clear and reliable guide on how to assemble the Besta shelving unit completely without tools?
Oh, mansi, I love questions like this! 😀 Unfortunately, the Besta is known for using screws and dowels.
However: There are gadgets on the market like small cordless screwdrivers with the right bits that feel very lightweight in the hand—almost no tool feeling anymore. Completely without tools, though? Most of the time that’s more of a “DIY event” requiring some improvisation.
If you only want to assemble the shelf temporarily, maybe tape or some other support could work, but stable and without tools? That’s tricky! But hey, if you dare, give it a try and then share how the adventure went!
mabla
20 Jan 2024 15:03
Furniture unit like Besta completely without tools?
No.
You need at least a hex key, which is usually included. Without tools, it will be very wobbly or not properly stable at all.
Palenar
20 Jan 2024 16:12
Attempting to assemble an IKEA Besta shelving unit without any tools is, from a technical standpoint, hardly realistic.
The assembly involves several components that need to be connected precisely:
- Dowels for exact fitting connections
- Cam fittings (cam locks) that must be tightened using the supplied Allen key
- Screws for stability and load-bearing capacity
The IKEA Allen key is minimalist and very handy. If no tools at all are available, improvised tools might be used, but these often lack the necessary force or precision.
Is there an instruction guide for assembling without tools? No, but the following tips may help:
- Check if you can use small, light hand tools as an alternative
- Plan the assembly carefully using the supplied instructions to reduce issues
I’m curious: Do you have specific reasons for wanting to work completely without tools? This might help to consider an alternative approach.
kaubi
20 Jan 2024 17:44
The Besta system is based on fasteners that cannot be properly secured without tools. These cam locks and screws are designed to reach full stability only when tightened with the IKEA hex key or a corresponding tool.
There is no official instruction allowing tool-free assembly, precisely for safety reasons. Tool-free alternatives result in unstable furniture that can be damaged under load.
For minimal tool use:
- The IKEA hex key is compact and always included in the package.
- It is sufficient for the assembly.
If you want a quick build, I recommend using the hex key and organizing all parts carefully before you start.
dijan
21 Jan 2024 09:16
Palenar schrieb:
I’m curious: Do you have specific reasons for wanting to work entirely without tools?
Good question! Maybe someone wants to assemble the shelf somewhere without tools readily available, or they have children nearby who shouldn’t handle tools.
Alternatively, with patience and a bit of creativity, it’s possible to screw in some screws by hand, but the effort usually outweighs the time saved. Maybe just attach the small Allen wrench to your keychain—it’s barely bigger than a USB stick 😉
