ᐅ How can Ikea BESTA units be securely mounted to the wall?
Created on: 16 Oct 2021 08:14
peo_ren3
peo_ren3
16 Oct 2021 08:14
Hello everyone, I plan to mount my Ikea Besta shelving unit on a wall and want to make sure the installation is stable and secure, especially since the shelf will need to support a considerable amount of weight. My wall is made of concrete, and I have the original Ikea wall fixings, but I’m unsure if these are sufficient or if I should use special anchors and screws. Has anyone had experience securely attaching Besta units to concrete walls? What materials work best, what should I pay attention to, and how can I prevent the shelf from becoming loose or even falling over time? I would appreciate well-founded tips and recommendations, including practical advice on preparing the wall and the best approach for drilling and mounting.
Jaime
16 Oct 2021 09:02
Basically, attaching Ikea BESTA units to concrete walls is a sturdy solution when the correct anchors and screws are used. The original screws from Ikea are generally suitable for simple walls, but for concrete, I recommend using high-quality expansion anchors or, even better, heavy-duty anchors. Important points to consider: - The anchors must match the drill hole diameter and the wall thickness. - Always use a hammer drill before drilling to ensure clean holes. - Do not overtighten the screws, but make sure the unit is securely fastened to avoid any movement. I would also suggest slightly weighting the unit during screw installation to prevent it from shifting upward while tightening the screws.
Devin
16 Oct 2021 09:45
Use 8mm (5/16 inch) wall plugs and screws that fit precisely. Drill at least 6cm (2.4 inches) deep. Use a spirit level during installation. Afterwards, check that everything is securely fastened.
BENBI
16 Oct 2021 11:18
Regarding the secure wall mounting of an Ikea BESTA shelf unit to a concrete wall, I would like to explain a few points in more detail. First of all, precise preparation of the wall is recommended, especially if it is a load-bearing exterior wall. The main risk is accidentally damaging cavities or electrical/plumbing installations. Therefore, always scan the wall with a detector before drilling. For concrete walls, I personally prefer using nylon expansion anchors with an 8 mm diameter (5/16 inches) because they hold best under the weight load of the shelf unit. A hammer drill is also important to create a clean and accurately sized hole, otherwise the anchors will not grip properly. Then, use screws with a suitable head type, such as countersunk or hex head, to ensure the load is distributed evenly. The shelf should have at least two mounting points per wall section. Finally, it is advisable to retighten the screws after a few weeks to compensate for any settling. By the way, if the back panel of the BESTA shelf is thin, be careful not to overtighten the screws to avoid damaging the material.
JONKO
16 Oct 2021 12:03
I can completely understand your concerns about stability. I felt the same way when I installed my BESTA shelving system. I was always worried that over time it might loosen and something could fall. My tip: Take your time during assembly, and if you notice even a slight wobble, make adjustments right away. What helped me was using wall plugs combined with an additional metal bracket mounted underneath the shelf, so that not only the wall load is supported but the horizontal stability is also improved. Also, my advice: Get help when drilling to ensure the holes are perfectly vertical. That makes a big difference.
rickey
17 Oct 2021 07:52
What helped me back then was lightly dampening the wall before installation. This made the drill holes cleaner and the anchors held better. I’m not sure if this would be useful for you as well, since concrete can have varying porosity. However, it was a small trick that gave me extra security.
