ᐅ How can I build an IKEA Besta with adjustable compartments as a multifunctional piece of furniture?
Created on: 31 Jul 2022 09:12
GamifarHello everyone, I want to convert my IKEA Besta shelving unit into a multifunctional piece of furniture with adjustable compartments. Specifically, I’m looking for advice on how to arrange the shelf sections so that I can later combine doors, drawers, and open or closed compartments in a flexible way—ideally so that everything can be easily reconfigured and adapted to different needs. Does anyone have experience with assembling this or tips on the best way to add or swap modular elements? Any advice on stability and possible additions to make the furniture more versatile would also be very helpful.
flo-Theres31 Jul 2022 11:05It is important to establish a clear grid from the beginning so that different elements like doors or drawers can be installed accurately later on. Generally, it is advisable to work with the standard dimensions of Besta components. This also makes future additions easier if the usage needs to change. I also recommend using sturdy side panels and, if necessary, internal frames to ensure the structure remains stable despite changes in the layout. Additionally, planning the back panel is crucial: it should be sturdy and precisely matched to the selected compartments.
flo-Theres schrieb:
As a rule, it is advisable to work with the standard dimensions of the Besta components. This also makes later additions easier if the usage should change.Thank you, that sounds reasonable. Could you please explain in more detail how you work with the interior frames? I ask because I’m concerned the shelving unit might become unstable if the compartments are too large or vary too much in size.F
flo-Theres31 Jul 2022 15:30The internal frames are basically additional reinforcements that you install inside the Besta frame. They reduce the span of individual shelves so they don’t sag. This is especially helpful for large adjustable compartments to ensure stability. Usually, you can use simple wooden edge profiles or metal brackets for this, which can be installed unobtrusively. This way, you can precisely adjust the height of the compartments and increase their load capacity.
