ᐅ IKEA Besta – How Can I Replace Damaged Panels Myself?
Created on: 3 Nov 2016 18:07
SOBIREO
SOBIREO
3 Nov 2016 18:07
I own several IKEA Besta cabinets, and unfortunately, some of the panels are damaged—whether from scratches, dents, or slight warping. Since I would like to maintain and repair the furniture myself, my question is: How can I independently replace the damaged panels on IKEA Besta cabinets without having to disassemble or discard entire units?
I would appreciate information on which tools are needed, the best way to remove and reinstall the panels, and any particular points to watch out for to avoid causing further damage to the furniture.
Additionally, I am interested in whether original replacement parts from IKEA are available for purchase or if alternative options are recommended.
I look forward to your tips and experiences!
RuPablo7
3 Nov 2016 18:22
for the replacement, you usually need an Allen key, a screwdriver, and possibly pliers. Panels can be removed by first unscrewing the screws from the connectors. After that, you can take out the panel and replace it with a new one. IKEA rarely sells individual panels separately, so it's best to ask directly in the store.
tolokau
3 Nov 2016 19:03
I am happy to explain the replacement process for IKEA Besta panels in more detail:
1. Preparation: Ensure you have a clean workspace and gather all necessary tools (4mm Allen key, Phillips screwdriver, possibly a hammer drill if some screws are damaged).
2. Removal:
- Fully open the cabinet and remove doors and drawers for better access.
- Locate the connecting screws on the cabinet parts, usually hidden on the inside.
- Carefully loosen all screws with the Allen key. Important: Do not fully unscrew them unless the panel needs to be completely removed; just loosen them if only detaching the panel.
3. Removing the panel:
- After loosening the connections, carefully lift out the damaged panel. Be cautious with plywood or MDF panels, as supporting battens can break.
4. Installing the new panel:
- Check if the replacement fits exactly or if you need to make adjustments (e.g., drilling holes).
- Insert the panel, screw it in, and tighten the screws evenly.
5. Completion:
- Reinstall the doors and drawers and check their function.
A common mistake is overtightening the screws, which can loosen the connections over time. Also, make sure to use screws of the appropriate length!
If replacement panels are not available, comparable wooden panels with the same dimensions can be cut locally.
FRAVIN
3 Nov 2016 19:45
It is also important to distinguish between the types of panels used by Besta:
- Side panels are often load-bearing elements and should be handled with care.
- Shelves are usually easier to replace.
IKEA generally provides spare parts only through customer service if you have the exact product number. You can find this under the panels or in the assembly instructions.
Before disassembling, document the position of all screws, as this will make reassembly easier.
SOBIREO
3 Nov 2016 20:12
tolokau schrieb:
1. Preparation: Ensure you have a clean workspace and gather all necessary tools (4mm hex key, Phillips screwdriver, possibly a hammer drill if screws are damaged).
Thank you for this detailed explanation! I have a more specific question: When removing the panels, do I always need to empty the entire cabinet and remove all the doors, or are there certain Besta variants that allow the panels to be replaced without taking the whole carcass apart?
This is especially important for large combinations, which I would prefer not to disassemble completely.
KAMERON
3 Nov 2016 20:47
Basically, the Besta cabinets are modularly designed, allowing individual parts to be replaced.
However, for most models, at least one part of the front (door or drawer) must be removed to safely take out damaged panels. In some cases, a shelf can be removed without dismantling the front.
For the side panels and back panels, it usually applies that the furniture needs to be at least partially disassembled to carefully replace the panels without compromising the stable structure.
Therefore, it is recommended to:
- Take photos or sketches beforehand
- Work step by step and check intermediate steps
A full disassembly is not always strictly necessary, but often helpful.
