Trevorfi334 Dec 2023 08:47Hello everyone,
I have several IKEA Besta cabinets at home that I use for media devices and books. What bothers me in everyday use is the quite significant dust buildup inside the cabinets—especially under the shelves and in hard-to-reach areas.
Since the Besta units usually have doors but are not completely airtight, I’m wondering: What effective methods are there to prevent dust accumulation inside IKEA Besta furniture? Are there any special tricks, materials, or approaches that can reduce the problem without having to constantly empty everything and clean manually?
I’m looking forward to your experience or technical tips on how to manage this issue long-term.
Hey,
first of all: Dust is an ever-present roommate, whether we like it or not 😅. But with BESTAs, there are a few things you can do to keep the inside a bit cleaner. I personally use small moisture absorber pads – those little bags that capture humidity. Dust tends to avoid damp areas somehow.
It also helps a lot to always keep the closet doors fully closed and to quickly wipe them down with a duster at least once a week. I know, it’s annoying, but it’s much better than scrubbing for hours. And: I stuck small felt pads in the lower corners, which help reduce dust by minimizing air circulation.
Give these little tricks a try; they’ve really helped me!
flo-Theres4 Dec 2023 11:41In short, I recommend:
- Installing cloths or padding made of antistatic material on the inside, as this reduces dust attraction.
- Regularly ventilating the rooms to keep dust levels low.
- Vacuuming or packing contents in airtight boxes to keep dust out.
The BESTA furniture itself is not airtight, which naturally makes keeping it dust-free more difficult. Therefore, the furniture’s surroundings play a significant role.
To systematically prevent the issue of dust accumulation in IKEA BESTA furniture, it is helpful to consider the topic from several perspectives:
1. Material & Construction: The BESTA units are usually made of melamine-coated particleboard, with open joints at the backs or door edges that allow dust particles to enter.
2. Air Circulation: Since the furniture is not airtight, the air in the living space also circulates inside the furniture bodies. Fine household dust settles there.
3. Preventive Measures:
- Using moisture regulators (e.g., silica gel packets) can indirectly help bind dust particles.
- Interior surfaces can be lined with antistatic cloths or even films to reduce static electricity buildup.
- Always keep doors properly closed to minimize the amount of dust inside the furniture.
4. Content Organization: The best method is to store dust-sensitive items in boxes or protective covers. This significantly reduces the amount of dust inside.
Could you describe in more detail how your BESTA models are constructed? Are the back panels simply slotted in or screwed? What type of doors do you have (glass, wood)? Also, how often do you currently clean them?
Trevorfi334 Dec 2023 16:28Laukau5 schrieb:
Could you describe in more detail how your BESTA units are constructed? Are the back panels simply slotted in or screwed? What kind of doors do you have (glass, wood), and how often do you usually clean them?Thank you for the detailed analysis! My BESTA units are built with back panels that are only slotted in, no screws. The doors are wood with a light magnetic catch, but they close well. I usually use three compartments and empty them completely about every 2 months to wipe them down. Still, I seem to be constantly accumulating dust. I haven’t tried any antistatic films or similar products yet.
So, I’m specifically looking for practical solutions that work long-term when using media devices inside the cabinet, without having to repeatedly remove and put the equipment back.
