ᐅ Which installation screws are suitable for IKEA Metod tall cabinets?
Created on: 5 Jan 2024 14:23
felenHello everyone,
I plan to install several IKEA Metod tall cabinets in my kitchen and want to make sure I use the appropriate mounting screws that are both sturdy and compatible.
My specific question is: What type of mounting screws are best suited for installing IKEA Metod tall cabinets, especially regarding material, length, and diameter?
Are there any special screws to watch out for to ensure the cabinets are securely fixed to the wall and the load capacity is guaranteed? I would also appreciate advice on any necessary wall plugs or additional fasteners.
Thanks in advance for your experience and tips!
Hello felen,
I want to provide you with a comprehensive answer because the choice of screws for Metod tall cabinets really has a big impact on stability and safety.
IKEA generally uses particleboard screws for assembling the furniture; these are screws with a relatively coarse thread specifically designed for engineered wood materials. For wall mounting, especially with tall cabinets, the choice of screws and anchors is crucial and depends, among other things, on the type of wall (e.g., concrete, brick, drywall).
- Screws for furniture assembly: Usually about 3.5 to 4 mm diameter, around 30 to 50 mm (1.2 to 2 inches) long, depending on the part being fastened.
- Screws for wall mounting: It is advisable to use a larger diameter, typically 6 to 8 mm (0.24 to 0.31 inches), and a length that securely penetrates at least 50 to 80 mm (2 to 3 inches) into the wall material, depending on the wall type.
- Anchors: For solid walls, use sleeve anchors or expansion anchors; for drywall, special cavity anchors are recommended because simple plugs cannot support the load.
- Materials: Galvanized or stainless steel screws are durable and protect against corrosion. This is especially important in the kitchen.
I’m curious: What type of walls do you have? Do you already have mounting points, or will you be installing the cabinets on bare walls? This information would help to give a more specific recommendation.
Additionally, I would suggest not to under-dimension screws and anchors; it’s better to choose something a bit stronger since tall cabinets often hold heavy appliances (refrigerator, oven). Safety comes first.
If you need more details, just let me know!
GOLO42 schrieb:
I wonder: What type of walls do you have? Do you already have mounting points, or will you be attaching the cabinets directly to bare walls? That would help to give a more precise recommendation.That’s a really good point! Wall construction is often underestimated.
I once had the exact problem of using regular anchors that were not strong enough for my drywall. It dragged on until I finally bought special cavity anchors, which then held perfectly.
You only realize this when you’re standing in front of the wall, puzzled, asking yourself, “Why isn’t this holding?” So here’s a tip for everyone: Make sure to check exactly what material your wall is made of, and if needed, get advice at your local hardware store.
As for screws, I had good experience with zinc-plated chipboard screws, just as GOLO42 described. That should really keep you on the safe side.
felen schrieb:
Which type of mounting screws are best suited for assembling IKEA Metod tall cabinets, especially regarding material, length, and diameter?Here is a brief "mini-tutorial" on mounting screws for Metod tall cabinets:
1. Furniture assembly:
- Use chipboard screws with approximately 4 mm diameter and 40-50 mm (1.5-2 inches) length.
- Material: galvanized for rust protection.
- These screws are ideal for securely joining the cabinet parts.
2. Wall attachment:
- Screws should have at least a 6 mm (1/4 inch) diameter.
- Length should be at least 60-80 mm (2.5-3 inches) to reach deeply enough into the wall material.
- Note: The wall type determines the choice of anchors! For concrete or brick walls, use expansion anchors or metal cavity anchors.
- For drywall (plasterboard) walls, use hollow wall anchors such as toggle bolts or molly bolts.
3. General tips:
- Avoid using excessive torque when tightening screws with a cordless drill to prevent damaging the MDF panels of the Metod cabinets.
- Pre-drilling is often not necessary as chipboard screws are self-tapping.
If possible, follow the screw specifications provided in the IKEA assembly manual. This is usually a reliable guideline tailored to the furniture.
It is essential that the screws can support the full weight of the loaded tall cabinets and that you anchor them into stable, load-bearing masonry.
