ᐅ Which Ikea Pax wardrobes are particularly durable and sturdy?
Created on: 16 Apr 2023 08:37
Bopra
I am considering buying a new Ikea Pax wardrobe for my bedroom. It is especially important to me that the wardrobe is durable and sturdy, as I plan to store a significant amount of weight and it will be opened frequently.
My specific question is: Which Ikea Pax wardrobes or which variants within the Pax series are known to be particularly durable and robust? Are there differences in materials, construction, or load capacity that one should definitely consider before purchasing?
I would appreciate any experiences, recommendations, and possibly tips on optimal maintenance or reinforcement of the wardrobes. Thanks in advance!
Ryder35
17 Apr 2023 08:05
JAFUHAU schrieb:
Regular maintenance, such as tightening screws or oiling the hinges, has really helped here.
Exactly, that is often the key.
I would also recommend, if possible, not to fully load the cabinet to its maximum capacity. This helps protect the hardware and the shelves.
LOGEMIN
17 Apr 2023 10:42
I’m happy to provide a structured overview of the factors that influence the durability of a Pax wardrobe:
1. Materials
- Choose fronts made of MDF or solid wood, as these are more durable than particleboard.
- The back panel is often thin; reinforcement can be advisable.
2. Installation
- Wall mounting is absolutely necessary to prevent tipping hazards.
- Regularly check screws and tighten them if needed.
3. Interior fittings
- Metal rails and full-extension drawer slides significantly increase lifespan.
- Reinforcements in the base area help with load-bearing capacity.
4. Maintenance
- Avoid moisture on the surface, as particleboard can swell.
- Oil the doors and hinges every few months.
Summary: A Pax wardrobe with MDF fronts, metal fittings, and regular maintenance during installation and upkeep lasts much longer than the basic standard version. Also important: avoiding overloading and securing the wardrobe to the wall are essential.
Wesley
18 Apr 2023 07:34
LOGEMIN schrieb:
A Pax wardrobe with MDF fronts, metal fittings, and regular maintenance during assembly and care lasts significantly longer than the basic standard version.
Great summary! 🏆 That’s exactly it: you almost have to treat the Ikea Pax wardrobe like a pet – with love and attention!
A small tip at the end: for those who prefer a more personalized approach, you can optionally add a thin acrylic protective sheet on the shelf to prevent moisture and scratches.
This really leaves nothing standing in the way of a sturdy and long-lasting use!
