ᐅ Which Ikea Pax wardrobes are particularly durable and sturdy?
Created on: 16 Apr 2023 08:37
Bopra
Bopra
16 Apr 2023 08:37
I am considering buying a new Ikea Pax wardrobe for my bedroom. It is especially important to me that the wardrobe is durable and sturdy, as I plan to store a significant amount of weight and it will be opened frequently.
My specific question is: Which Ikea Pax wardrobes or which variants within the Pax series are known to be particularly durable and robust? Are there differences in materials, construction, or load capacity that one should definitely consider before purchasing?
I would appreciate any experiences, recommendations, and possibly tips on optimal maintenance or reinforcement of the wardrobes. Thanks in advance!
Wesley
16 Apr 2023 09:11
Bopra schrieb:
Which Ikea Pax wardrobes or variants within the Pax series are particularly durable and robust?
Hi Bopra, that’s an important question! The Pax series is quite versatile, and when it comes to durability, it often depends on the combination.
Personally, I find the models with solid wood fronts or at least reinforced MDF doors to be more long-lasting. The standard doors made of painted particleboard look nice but are more prone to dents and moisture damage.
Also, for the interior, look for metal rails and drawers with a soft-close feature – these tend to be sturdier than basic ones.
One more tip: be sure to secure the wardrobe to the wall; this helps it last longer and prevents wobbling! So, in short: durable fronts + sturdy interior components + wall mounting = long-lasting furniture satisfaction 😉
Kenon70
16 Apr 2023 09:43
Pax with melamine coating last longer because the surface is more resistant. Metal reinforcements in the frame are also important. Doors made from solid material are more durable than plastic fronts.
KARJU
16 Apr 2023 10:07
An objective assessment of the durability of Pax wardrobes:
- Materials: Most Pax models are constructed from veneered particleboard or MDF. The wardrobe frames are consistently designed for stability, but load capacity varies depending on the internal fittings.
- Doors: Solid wood or high-gloss lacquered MDF doors offer better resistance to impacts and moisture compared to veneered particleboard.
- Reinforcement: Installing wall mounts is technically required to achieve maximum stability.
- Load capacity: Official specifications state a maximum load of 15-20 kg (33-44 lbs) per shelf.
For particularly robust options, the model with frame-reinforced doors and metal drawer runners is recommended.
Proper installation and avoiding overloading also help extend the wardrobe’s lifespan.
V
vinpau
16 Apr 2023 11:26
KARJU schrieb:
An objective look at the durability of Pax wardrobes
I agree! Last year, I got a large Pax wardrobe with the solid doors myself and I’m really happy – it still looks great even after heavy use. 😊
One thing I can add: if you often change the load, for example with many books, it’s also helpful to install additional shelves to better distribute the weight.
And honestly, I think assembling it can be tiring, but investing in a sturdy interior is definitely worth it!
JAFUHAU
16 Apr 2023 13:19
How do you feel about the cabinets after longer use?
I have a Pax wardrobe that has been standing in my home for almost 5 years now. What I’ve noticed is that the rollers and hinges can loosen up a bit over time, especially with daily use. Regular maintenance, like tightening screws or oiling the hinges, has really helped.
I think when it comes to sturdy furniture, you shouldn’t just consider the material, but also the care and handling. And honestly, how often do we actually take the time for that? From my experience, especially with affordable furniture, it’s often better to invest in maintenance and service rather than just focusing on the price.
