ᐅ Which assembly steps are particularly important for the IKEA Hemnes series?
Created on: 20 Feb 2023 09:12
lilapra
Hello everyone, I am currently assembling my new IKEA Hemnes wardrobe and want to make sure I pay special attention to the important assembly steps to avoid mistakes. Which assembly steps for the IKEA Hemnes are particularly crucial and should be carefully followed to ensure the furniture is stable and free from damage later on? Are there any tips on how to avoid common pitfalls? It would be great if you could share your experiences, preferably with notes on critical work stages or advice regarding the assembly materials.
Vinlen schrieb:
The pre-drilled holes in Hemnes are usually prefabricated and standardized. Nonetheless, caution is advisedThank you, that’s good to know, as I only wanted to adjust the back panel slightly and was considering drilling additional holes to secure the cabinet better. Maybe it’s better not to do that.
Are there alternatives for even more stable wall mounting if no further drilling into the furniture components is recommended?
A recommended alternative for reinforcement without additional drilling is the use of quality brackets or metal reinforcements that are mounted between the cabinet and the wall, without the need for new holes in the furniture.
The IKEA wall fasteners are often sufficient, but if the location is exposed to wind or the cabinet is moved frequently, investing in more robust connectors is worthwhile.
Another option is screws and anchors recommended by the manufacturer, specifically designed for high load capacities. This improves stability without affecting the functionality of the furniture.
edisondan21 Feb 2023 16:12I would like to emphasize the point about door installation again: The doors of the Hemnes come with concealed hinges that offer multiple adjustment options.
- Use these adjustment screws to align the doors properly and ensure an even gap to the side panels.
- It is important to adjust the hinges only in small increments and check after each adjustment that the door still closes smoothly.
- Pay attention to the correct positioning during installation, as misaligned doors can cause damage to the hinges or the cabinet body over time.
