ᐅ Are there any tips for assembling Ikea Hemnes furniture more quickly and easily?
Created on: 9 May 2023 08:17
pojepau
Hello everyone, I am planning to get an Ikea Hemnes furniture piece, specifically a wardrobe. I have often heard that assembling Hemnes items can be quite time-consuming and sometimes a bit complicated, especially for those with little experience in furniture assembly. Therefore, I wanted to ask: Are there any tips or proven methods to make assembling an Ikea Hemnes piece faster and easier? Which tools, techniques, or approaches have worked well for you to make the process more efficient and less stressful? I look forward to your advice and experiences!
Dilen
10 May 2023 10:37
I would like to go into more detail about the assembly process here, especially for the Hemnes wardrobe: The construction usually starts with the side panels. I recommend carefully checking the drill holes and dowels beforehand, as there is often no allowance for tolerances, and even a slight misalignment can affect the fit. When joining the individual panels, it is helpful to use a rubber mallet to avoid damaging the surfaces.
Another tip: During assembly, it is advisable to tighten all screws initially with medium torque and only fully secure them in the final step. This allows for small adjustments if something isn’t fitting perfectly. The Hemnes, with its solid wood parts, is somewhat more demanding than simple shelving units. Have you had any experience with this type of furniture, or would a setup video be helpful for you?
pojepau
10 May 2023 11:45
Dilen schrieb:
Have you had experience with this type of furniture before, or would an assembly video be helpful for you?
Thank you for the detailed response! So far, I've mostly assembled simpler Ikea items, but the Hemnes series would be my first larger wardrobe. An assembly video could definitely help, especially to understand how the parts fit together. Does anyone know if Ikea offers official or reliable independent tutorials? And how long does it usually take you to assemble a Hemnes wardrobe? I expect it to take around 2-3 hours, but I’m open to any tips.
Gloriagl10
10 May 2023 12:53
For Hemnes cabinets, I recommend having a second person to help. One person holds the cabinet while the other screws it together. Also, insert the plastic wall plugs into the holes beforehand—this saves time when aligning. Generally, plan for 2 to 3 hours.
Paxton38
11 May 2023 08:06
pojepau schrieb:
Does anyone know if Ikea offers official or good independent tutorials?
Ikea usually provides official assembly instructions available for download, which are quite detailed. Additionally, there are many independent video tutorials on YouTube offering useful assembly tips. These videos often demonstrate practical tricks, such as proper alignment and the order in which parts should be assembled. The average assembly time depends on the model and personal experience, with 2–3 hours being realistic for Hemnes. Another important tip: allow yourself enough time and avoid rushing.
dijan
11 May 2023 09:19
Paxton38 schrieb:
Another important tip: Take enough time and avoid rushing.
Exactly! Stay calm, put on some music, have your coffee ready, and treat it as a little DIY project, not a source of stress. Everything will go much smoother that way. And if something doesn’t fit right away: stay relaxed, furniture like Hemnes is sturdy and won’t break easily. Good luck with the assembly!
