ᐅ Are there any tips for assembling Ikea Hemnes furniture more quickly and easily?
Created on: 9 May 2023 08:17
pojepauHello everyone, I am planning to get an Ikea Hemnes furniture piece, specifically a wardrobe. I have often heard that assembling Hemnes items can be quite time-consuming and sometimes a bit complicated, especially for those with little experience in furniture assembly. Therefore, I wanted to ask: Are there any tips or proven methods to make assembling an Ikea Hemnes piece faster and easier? Which tools, techniques, or approaches have worked well for you to make the process more efficient and less stressful? I look forward to your advice and experiences!
As a general rule, it is advisable to read the instructions thoroughly before starting and to carefully organize all the parts. Especially with Hemnes, it can be helpful to sort screws and small components into small containers to avoid constantly searching for them. Tools: A cordless drill with variable speed significantly speeds up the process, but be careful to set the correct torque to avoid damaging the wood. Additionally, a small hammer is useful, but should be used carefully to prevent scratching. It is also important not to assemble the furniture alone, but, if possible, with two people – this saves effort and time when handling heavier parts.
Paxton38 schrieb:
A cordless drill with variable speed significantly speeds up the processOh yes, a cordless drill is like a magician in furniture assembly! 😄 I would also recommend taking short breaks in between to avoid frustration – having some fun while building is important. Another tip I often use is to sort all screws by type and lay them out on a tray. This way, you won’t lose any parts and can always keep track of everything.
I think the whole Ikea assembly hype is greatly overrated. Sure, it takes a bit of patience, but “faster and easier” often comes down to expectations and preparation. If someone has trouble with the Hemnes furniture, in my opinion, it’s more due to a lack of basic DIY skills. Let’s be honest: if you have those skills, it’s no big deal. With the Hemnes cabinets, all parts are well designed, nothing mysterious. So, want to save time? Just be a little more patient!
To save assembly time, I recommend: 1) Checking all parts in advance. 2) Assembling in a logical order, as described in the instructions. 3) Using a cordless screwdriver with the correct bit size. 4) Paying attention to the quality of the screws. 5) For Hemnes, attach the back panel last. This way, you avoid rework.
Hello, from my experience I can say that it is especially important to prepare the assembly area in advance: have enough space, a soft surface to protect the parts, and good lighting. Also, gather all the parts in an organized order on the floor and proceed step by step. It is also advisable not to tighten all the screws fully right away, but to leave them loose at first to allow for adjustments in positioning. Once everything fits correctly, you can tighten all the screws. This is particularly helpful with Hemnes, as many parts need to interlock.
