ᐅ Which tools are most important for assembling the Ikea Hemnes furniture?
Created on: 7 Nov 2019 08:17
DigugiHello everyone,
I’m planning to assemble an Ikea Hemnes chest of drawers soon and want to be well prepared regarding the tools needed. Since I’ve assembled several Ikea furniture pieces before, I know that good preparation is half the battle. My question is: which tools are really essential for assembling Ikea Hemnes furniture?
I’m especially interested in whether specific screwdriver types (Phillips, flathead), a cordless drill, a hammer, or perhaps special tools like Allen keys significantly ease the process. It would also be helpful to know which tools can safely be left out and whether Ikea’s included accessories are sufficient or if it’s better to supplement them with your own.
I look forward to your experiences and recommendations, especially if you have tips to make the assembly more efficient and less frustrating.
Hello Digugi,
based on my experience, the most important tools for assembling Ikea Hemnes furniture are:
- A good Phillips screwdriver (PH2), as most Ikea screws have this type of head.
- An Allen key (usually included), for special connections.
- A rubber mallet can be helpful when parts need to be tapped gently to achieve a better fit.
A cordless drill is not mandatory but can significantly speed up the work if it has a torque limiter to avoid overtightening screws. Flathead screwdrivers are rarely needed since Ikea typically uses Phillips screws.
The tools provided with Ikea furniture are usually sufficient but do not replace careful handling during assembly. I recommend prioritizing quality over quantity when it comes to screwdrivers.
Hi Digugi,
I would say the absolute MVP among the tools for the Hemnes furniture is the classic Phillips screwdriver. Ikea really loves Phillips screws. If you already have the right screwdriver, you’re off to a great start.
And of course, the cordless drill is great, unless you’re a pro at screwing by hand, but as I mentioned, be careful with the torque or you might damage the wood.
And hey, don’t underestimate the Allen key! It’s like the secret agent among tools—always there when you don’t immediately notice it.
Oh, and for the final tapping, a small rubber mallet is invaluable! It will make the furniture sturdy and look great in the end.
Enjoy the assembly!
Enjoy the assembly!
Last year, I assembled a Hemnes chest of drawers and can confirm that the tools mentioned are very important. To be honest, I was a bit unprepared on the first try and only used the included Allen key. That made things significantly more difficult because I had to tighten the screws by hand constantly, and achieving precise results was almost impossible.
What really helped me later was a good Phillips screwdriver and a cordless drill, which made the assembly much faster. But here’s a tip from me: take your time and practice using the cordless drill carefully beforehand to avoid over-tightening – that frustrated me quite a bit at the beginning.
I think the most important takeaway is not to rush and to have the right tools ready – it makes the whole experience much more relaxed!
Great thread!
I can only agree with what’s already been said: a Phillips screwdriver should definitely be your top priority! I’ve assembled countless Hemnes furniture pieces, and without a cordless drill, I would have gone crazy. Especially when working alone, it saves a lot of time and frustration.
Here’s a little tip from me: if you apply a bit of lubricant (like wax or dry soap) carefully to the screws, they’ll turn more easily and the material is protected. Also important: always apply even pressure to prevent the screws from slipping.
And hey, the included Allen key is nice, but usually pretty small and uncomfortable. For situations like this, I prefer to have a set of Allen (hex) or Torx keys—it makes screwing much more comfortable.
Good luck with the assembly—you’ve got this!
[@Declan55, post: u3s7v3, member: XXX] Here’s a little tip from me: If you carefully apply a bit of lubricant (such as wax or dry soap) to the screws, they turn more easily and the materials are better protected.
That sounds reasonable at first, but I would be cautious. Abrasive substances or creams on the screws might reduce the adhesion between the wood and the joint, potentially causing the screws to loosen over time. I would prefer to see more scientific evidence or user experiences before recommending this.
Basically, I think the importance of tools depends a lot on one’s experience. A cordless drill is obviously very useful, but you should be able to control its torque well. For casual DIYers, a good-quality Phillips screwdriver is often better, as it minimizes the risk of over-torquing.
Also: Ikea often includes mini tools with their products, but their ergonomics are usually suboptimal. In my opinion, it often makes sense to purchase replacement tools.
