ᐅ Which tools do I need to disassemble IKEA Hemnes furniture?
Created on: 31 Jul 2024 08:13
prafu
prafu
31 Jul 2024 08:13
Hello everyone, I am planning to dismantle my IKEA Hemnes wardrobe and would like to know in advance which tools are absolutely necessary for this. It is the classic Hemnes model, usually assembled with common fasteners like dowels and screws. Since I prefer not to buy multiple tools, it would be great if you could provide me with a comprehensive list of tools I will need to safely take the wardrobe apart without causing any damage. Which screwdrivers, special tools, or possible aids are essential for an easy dismantling? Thanks in advance for your advice!
benon
31 Jul 2024 08:22
Hello prafu, that’s a good and important question, especially since the Hemnes models often come with different types of screws and connectors. Basically, you will need:
- A Phillips screwdriver (PH2 usually fits)
- An Allen key (often included)
- A small flathead screwdriver (for small prying tasks, e.g., to remove nails or clips)
- Possibly a cordless drill with suitable bits if you have many screws
- A rubber mallet if you need to gently loosen parts without damaging them
This should be sufficient for most IKEA furniture, including Hemnes.
Dustin
31 Jul 2024 08:30
Only Phillips PH2 and the Allen key that comes with the furniture. With these, you can remove everything.
Jensson
31 Jul 2024 08:45
Hello prafu,
I’m happy to help you with a simple step-by-step guide and some tool recommendations:
1. Remove the drawers, usually hand force is enough.
2. Take off the back panel – often just a narrow flathead screwdriver is needed if the back panel is attached with staples.
3. Remove the screws, typically Phillips PH2 or 4 mm Allen (hex) screws.
4. For the connectors (plastic dowels or metal fasteners), you usually don’t need a special tool; most can be loosened by hand or with a screwdriver.
Tip: If you organize and store the screws and connectors separately, you can easily use them again during reassembly.
Watch out for common mistakes:
- Avoid prying or using excessive force.
- Don’t drive screws in too deep so they can be easily removed later.
Summary: For the Hemnes, you’ll need at least a Phillips PH2 screwdriver, a medium-sized 4 mm Allen (hex) wrench, a small flathead screwdriver, and ideally a small box to keep screws and connectors.
gregto
31 Jul 2024 09:05
Hello prafu, in addition to what has already been mentioned here:
A cordless drill is useful but should be used carefully, as too much torque can damage parts. Sometimes Hemnes models also have metal cam locks (round connectors); in that case, a small screwdriver or even a special cam lock tool, which IKEA sometimes includes, is recommended.
One more tip: A flat plastic spatula can help you gently loosen a back panel from the carcass without damaging the wood.
With these tools, you will be well prepared.
Marcellela
31 Jul 2024 09:13
A Phillips screwdriver (PH2) and a 4mm (5/32 inch) Allen key are usually sufficient. This is pretty standard for Hemnes.
