ᐅ Which tools do I need to assemble IKEA Besta units quickly under time pressure?
Created on: 22 Jun 2024 09:17
Muixneo
I am planning to assemble an IKEA Besta sideboard soon but have very limited time and want to make the assembly process as efficient as possible. From your experience, which tools are absolutely essential when assembling a Besta unit under time pressure? I’m especially interested in which hand tools or possibly power tools can significantly speed up the work without compromising quality or stability. Besides the usual Allen wrench included in the package, are there any other tools that help make the process sturdy and quick? Any recommendations, including useful accessories or small tips, would be greatly appreciated.
For assembling IKEA Besta under time pressure, I recommend the following tools:
- Cordless drill driver with a flexible angle attachment, due to tight spaces
- Suitable hex key bits in various sizes
- Phillips screwdriver as a backup
- Rubber mallet for assembly without damage
- Tape measure for quick measurements
The cordless drill driver should have stepless torque control to avoid damaging the workpiece. Besta materials are mostly MDF or particleboard with a laminated surface, so avoid using a drill with too much power to prevent surface fraying. An angled attachment is helpful but not absolutely necessary, depending on the working environment.
When working under time pressure, it is important that the tools are ergonomic and fit well in the hand to avoid fatigue. For IKEA Besta, I recommend:
- A cordless screwdriver with an adjustable-height handle or a compact design
- A set of standardized hex (Allen) bits
- A rubber mallet to prevent bruising accidents
Additionally, sorting the components beforehand is useful to avoid losing time during assembly. As mentioned earlier, the torque setting should be kept as low as possible to prevent material fraying.
klo61 schrieb:
Important: Set the torque low and start slowly. That sounds like a sensible approach. Would you recommend testing the tool first on a scrap piece of wood to get a feel for the torque? Or is experience enough? I have assembled some furniture before, but under time pressure, mistakes can happen quickly.
Muixneo schrieb:
Would you recommend testing the tool first on a scrap piece of wood to get a feel for the torque?Yes, definitely. Especially when working under time pressure, it’s best not to experiment for the first time on the actual furniture. A trial run on scrap wood provides confidence and reduces mistakes. If you don’t have scrap wood available, use an inconspicuous corner if possible. This definitely saves time and frustration.
