ᐅ How do I modify IKEA Hemnes furniture for accessible use?
Created on: 25 Feb 2024 08:17
tu-pa
tu-pa
25 Feb 2024 08:17
Hello everyone, I want to modify my IKEA Hemnes wardrobe for barrier-free use and am hoping for tips here in the forum. Specifically, I am looking for ways to improve the accessibility of the wardrobe components, especially for parts that are otherwise difficult to reach—such as with limited grip strength or reduced mobility in the arms and fingers. I am particularly interested in how to modify the doors or drawers so they are easier to open without requiring much force or complex gripping movements. Are there any proven modifications like changing handles, soft-close systems, or automated openings? Ideas for alternative operation methods that can be implemented with simple means are also welcome. Should the wardrobe be reinforced overall, or are there safety aspects to consider? I am grateful for any advice, especially practical tips that can be carried out using standard tools and IKEA parts.
Jukin
25 Feb 2024 09:43
Hello tu-pa, this is a very good topic! The Hemnes series is extremely popular, but barrier-free adaptations are useful and unfortunately not very well known. To open the doors, I recommend replacing the conventional handles with so-called “push-open” mechanisms or handles with better leverage. Dampers and soft-close systems can be retrofitted with some experience so that drawers almost open by themselves when you tap them. It is also important to adjust the height of the cabinet to individual needs, for example by using feet with adjustable height or removing the bottom trim to make it easier for wheelchair users to access the cabinet. Be careful when stabilizing: the Hemnes models are already quite stable, but to prevent tipping you should definitely secure them to the wall. If you are looking for motorized solutions, small door openers from the smart home sector are a good idea, but the effort and costs increase significantly. In general, I recommend defining the requirements precisely, then you can remodel step by step.
Filippo
25 Feb 2024 11:02
I’m happy to add some details: For accessible use, the handles should be as ergonomic as possible. Ideal examples are D-shaped or elongated bars that provide a good grip without requiring much force. A simple option is to replace standard knobs with ones that have a larger surface area or even textured finishes – this improves grip security. For drawers, additional gliders or soft-close mechanisms from third-party manufacturers can be installed under the wooden sliding profile, which not only allow smoother movement but also reduce noise. Especially with partial locks, there are models that can be opened even by people with limited strength. The height is also important: for wheelchair users, it often makes sense to use cabinets with open fronts or modified internal drawers to simplify access. Another option to consider is reducing the number of doors, for example by using sliding doors, which may not be standard but could be achievable with modifications. My question to better understand your situation: Are limitations only in the hands, or also affecting the upper body/arms? Depending on this, I would recommend different lever distributions and opening aids.
LOGEMIN
25 Feb 2024 12:56
[@tu-pa] I recently created a mini-guide specifically for this question. I’ll outline the possible renovation steps in the order you should ideally approach them:
- Analysis: Which functions are difficult to use? Doors, drawers, or both?
- Handle replacement: Swap out for ergonomic ones, e.g., elongated pull handles or grips with rubber coating
- Opening mechanisms: Install push-to-open or soft-close components
- Adjust the height or lower the bottom elements for better accessibility
- Securely fasten the cabinet to the wall for safety
- Optional: Retrofit small electric openers, e.g., activated by push buttons
A common mistake is to jump straight to technical solutions without improving the basics first. Often, handle replacement and soft-close features alone eliminate about 70% of barriers. Securing the cabinet to the wall is particularly important to prevent any tipping. If you like, I can compile a list of suitable components for you.
tu-pa
25 Feb 2024 15:19
Filippo schrieb:
My question to understand your situation: Are the limitations only in the hands, or do they also affect the upper body/arm area? Depending on that, I recommend different leverage setups and opening aids.
Good question, Filippo! The primary limitation is in grip function, especially when it comes to handling small buttons or handles with little surface area. Mobility in the shoulder area is not fully restricted, but energy-efficient handling is preferred. Additionally, the cabinet is located in a small apartment, so the modification should be as space-saving as possible. Motorized opening is more of a nice-to-have; I prioritize mechanical solutions that do not require external power. The goal is for, for example, guests with temporary hand issues or elderly family members to easily open and close the cabinet.
Dilen
25 Feb 2024 17:48
Based on the information provided so far and your detailed description, here is a precise renovation plan focusing on mechanical and practical measures:
- Handle replacement: Use elongated, textured rubberized handles or compact bow handles that can be gripped with the whole hand, not just the fingers
- Door openers: Install push-to-open hinges so that doors open with light pressure and can be pulled open without a handle
- Drawers: Add soft-close slides that open with a gentle pull, optionally with a one-handed lock to prevent closing too tightly
- Interior layout: Use removable drawer inserts so that items don’t have to be stored deep inside the cabinet
- Height: Ensure that the lower units are not too low; access should be as frontal as possible without bending down
- Safety: Use corner brackets on the back panel and always secure the cabinet to the wall with appropriate anchors, especially on drywall
A small additional tip: If you plan to do demolition yourself, use masking tape beforehand to protect surrounding surfaces. If your tools are not perfect, it’s better to consult a professional, as the handle hole spacing and the stability of joints can easily be damaged.
