ᐅ What are common mistakes when assembling an Ikea Metod kitchen?
Created on: 25 Aug 2022 14:23
Emmett64
Emmett64
25 Aug 2022 14:23
Hello everyone, I am currently planning the installation of my new Ikea Metod kitchen and would like to ask which common issues you have encountered or observed during the assembly of this system. I am especially interested in the points where most users face difficulties—whether it’s assembling the cabinets, aligning them, securing them to the wall, or putting together the doors and fronts. Are there typical pitfalls that can be avoided if you know in advance what to watch out for? Tips on handling the connectors and drawer mechanisms correctly are also welcome. Thanks for sharing your experiences and advice!
chen67
25 Aug 2022 15:47
Hey Emmett64, great question! 😄 From my experience, there are usually two main challenges with Metod: first, the exact fit of the individual modules – small deviations often occur if you’re not working perfectly straight. And second, the wall mounting. Many tend to take this lightly and don’t use the correct wall plugs or pay attention to the proper drilling depth. This can later lead to wobbly cabinets. Also, a small tip: always sort all the parts and read through the instructions completely before starting – it saves a lot of frustration later! Good luck with your kitchen 😎
FLONE41
25 Aug 2022 16:05
I think this topic is very important because I personally noticed how quickly mistakes can happen when rushing during the assembly of my Metod kitchen. For me, the main issues were assembling the cabinets in the wrong order and inaccurately aligning the fronts, which caused problems later. It’s really important to constantly check if everything is still level and square before moving on to the next step. When working with several people, clear communication is crucial to avoid everyone working in different areas at the same time, which can lead to errors.
draleo
25 Aug 2022 18:12
The most common mistakes when assembling the Ikea Metod kitchen can be summarized as follows: - Insufficient preparation and failure to follow the assembly steps according to the instructions lead to incorrect installation of the cabinets. - Improper wall mounting, especially neglecting the appropriate type of anchor for the wall material, results in unstable constructions. - Inaccurate alignment of the cabinet frames and fronts causes functional problems with opening and closing the doors. - Lack of checking for levelness, which is often worsened by uneven floors. - Carelessness in handling the delicate fronts, leading to scratches and damage. My recommendation is to strictly follow the included instructions, including the preparation steps, as well as to regularly check for levelness and stability during assembly.
barda6
25 Aug 2022 19:02
Wall mounting is often underestimated. Always use appropriate anchors. Check the flatness before installing the fronts.
Davebla
26 Aug 2022 07:44
It’s interesting to see what has already been mentioned here. However, I must point out critically that Ikea’s Metod series uses simplified instructions in some places, which could be problematic for people with limited DIY experience. There is sometimes a lack of clear explanation as to why certain steps are important, which can lead to misunderstandings. Additionally, you should not rely blindly on the standard wall plugs, since different types of fixings are needed, for example, with drywall or older walls. The issue of tolerances during installation is also critical, as small measurement deviations are often noticed too late, making full assembly difficult or requiring rework.
