ᐅ How do I properly assemble IKEA Metod cabinets with soft-close doors?
Created on: 7 Jul 2021 14:23
LUGUPO
LUGUPO
7 Jul 2021 14:23
I am currently planning to assemble IKEA Metod kitchen cabinets with soft-close doors and have several questions regarding proper installation. In particular, I am interested in how to correctly adjust the hinges on the soft-close doors so that they not only close smoothly but also function reliably over time. I am also wondering if there are any specific recommendations about the order of assembly—for example, whether the cabinet carcasses should be fully assembled before attaching the doors, or if it is better to do this simultaneously. I have the instructions on hand, but I find the details on the soft-close mechanisms and precise adjustments to be quite brief.
Does anyone have experience with the accurate assembly of these cabinets and tips on how to avoid mistakes? Are there any tricks to ensure the doors are aligned evenly? I would really appreciate a detailed explanation, as I want to avoid any errors as much as possible. Thanks in advance!
GUMARTINA
7 Jul 2021 15:02
Hi, when using soft-close hinges, make sure to use the adjustment screws at the front and the side. First, build the cabinet body completely, then attach the doors. Adjust the doors using the screws until they are perfectly aligned. This way, you avoid any binding.
kulau
7 Jul 2021 15:47
First about the sequence: it is definitely better to fully assemble and secure the carcasses before installing the doors. This way, you can check the stability and compensate for any inaccuracies in the base frame.
For the soft-close hinges, make sure they are properly seated – they must be fully clicked in for the damping function to work correctly. Adjustment is done via three screws:
- Lateral screw: adjusts the gap between the door and the carcass.
- Height screw: changes the vertical position.
- Depth screw: controls the door pressure and closing action.
A common mistake is to loosely attach the hinges for later adjustment – it is better to fully tighten them first and then fine-tune. The doors should close without resistance and feel slightly damped.
Have you checked whether the carcasses are standing on a level floor? Uneven floors can make alignment difficult. I also recommend using a spirit level during assembly to detect any misalignments early.
noge58
7 Jul 2021 16:05
Wow, great question! 😊 I recently installed my Metod cabinets as well, and the soft-close doors really make a difference! It’s important not to handle the hinges too roughly and to be patient when adjusting them. Make sure the screws on the hinges are tight but not overly tightened, or the function might get stuck.
Don’t be discouraged, you’ll manage it just fine! If you want, I can share some tips on how I aligned my doors.
Guyju
7 Jul 2021 16:47
Hello LUGUPO,
I’m providing you with a step-by-step guide on how I install the IKEA Metod cabinets with soft-close doors.
1. Preparation: Assemble the carcass first to check if all drill holes are correct and the parts fit properly. Use a spirit level to make sure everything is aligned.
2. Assemble the carcass: Use the supplied connectors but don’t tighten them fully yet, so you can make small adjustments later.
3. Secure the carcass: Once all sides are properly positioned, tighten all screws fully.
4. Install the hinges: Unscrew the hinges to set the basic position (depending on the model, they may be clipped on or hooked in).
5. Attach the door: Hang the door and position it roughly.
6. Adjust the door:
- Side to side (left/right): Use the corresponding screw to position the door.
- Vertical: Adjust the height so the door sits flush.
- Depth: Ensure the door lightly rests on the carcass without rubbing.
7. Test the function: Open and close the door several times to check the soft-close mechanism and adjust if necessary.
8. Final check: Inspect the carcass and doors to ensure everything is flush and the soft-close function works smoothly.
Common mistakes: Leaving screws too loose or overtightening them, assembling the carcass unevenly, or attaching doors before completing the carcass assembly.
I hope this helps you!
flota
7 Jul 2021 18:12
I would like to point out that the correct alignment of the soft-close hinges during installation is crucial for their long-term functionality. If the hinges are not properly engaged or if the doors are warped, this can quickly cause damage to the dampers.
Additionally, it is advisable to check the opening angle during hinge installation, as some IKEA Metod doors have different hinge configurations depending on the model. Another tip is to perform gentle test openings while adjusting the hinges before tightening everything completely.
