ᐅ How can I make IKEA Metod cabinets childproof?
Created on: 11 Sep 2015 07:38
Lafumau
I recently bought some IKEA Metod kitchen cabinets and now want to childproof them, as I have small children at home. My question is for anyone with experience or good tips: How can Metod cabinets be best childproofed without significantly limiting functionality or noticeably altering their appearance? I am thinking about possible locks, safeguards for cabinet doors and drawers, as well as potentially securing them against tipping over. Are there any reliable products (for example, from IKEA itself or third-party suppliers) or techniques that work particularly well? I would also appreciate any insights on installation.
Best regards and thanks in advance!
Lafumau
12 Sep 2015 08:06
Thanks for the initial helpful answers!
To answer your question, fidasi: The cabinets are already partially installed but not yet permanently fixed or fully equipped. This means that attachments to the wall and safety features can still be added without major disassembly. For me, the order would be:
- first, securing the cabinets against tipping by mounting them to the wall
- then, installing locks on the doors and drawers
My children are 2 and 4 years old, very active and curious, especially the older one who is very physically capable. I have already considered magnetic locks, but I prefer solutions that are as discreet as possible – I want to minimize any impact on the design.
Do you have experience with internal locks that can be installed nearly invisibly? Or would externally mounted hinge locks be better in terms of durability as well?
fidasi
12 Sep 2015 10:14
Lafumau schrieb:
I have considered magnetic locks before, but I prefer solutions that are as discreet as possible – the design should be affected as little as possible.
That’s an important point: Internal magnetic locks are indeed almost invisible from the outside since they are installed directly inside the cabinet. They operate with a special key that allows opening. Installation is a bit more complex, but for children aged 2 and 4, this is a very secure solution.
External clip locks are easier to install but often visible and less visually appealing. Additionally, children can sometimes accidentally damage them.
From my experience with Metod cabinets, it’s worth planning them carefully in advance – if the back panel is accessible, locks can be installed there very discreetly.
How are you securing the furniture against tipping? Do you have suitable wall anchors and screws? Different wall types require different fixing materials.
Are there any special considerations for your kitchen wall (e.g., drywall / plasterboard, brick, concrete)?
Ixvin
12 Sep 2015 12:28
Hello Lafumau,
regarding your question about internal fuses: The magnetic fuses are indeed discreet and can often be installed almost invisibly, especially if you already have the cabinet open.
One tip: Make sure that the cabinet’s opening mechanism is not affected, as this could cause it to stick or break.
Also, when mounting the cabinet to the wall, check if you can add extra brackets for stability – this increases safety, especially with active children.
I also recommend regularly checking the cabinets for looseness, particularly if children often climb on them.
One more question: Have you considered making certain areas inside the cabinets completely inaccessible to children, for example by using lockable doors?
lau-mar
12 Sep 2015 18:39
Regarding the childproofing of IKEA Metod cabinets, I recommend the following approach:
- Tip-over protection: Use the steel straps provided by IKEA along with appropriate wall anchors, matched to your wall type (concrete, masonry, drywall). Secure anchoring is essential.
- Door and drawer locks: Magnetic internal locks work well and are almost invisible. However, these systems require precise installation and usually involve modifying the back panel or attaching the lock inside the cabinet.
- Choose safety products that are compatible with your Metod configuration, especially considering different door opening mechanisms (e.g., recessed handles vs. knobs).
- Check the load on the hinges, particularly when locks are used, to avoid any undue stress.
Practical advice: Plan for fastening during installation to minimize later issues.
Always follow the manufacturer’s instructions and recommendations for wall mounting.
If uncertain, I recommend seeking professional advice.
teo33
13 Sep 2015 09:51
Simply attach child safety locks to every door and drawer, such as latch or slide bolt types. Secure the cabinets firmly to the wall to prevent tipping.
meson
13 Sep 2015 11:27
Magnetic internal locks combined with wall mounting are the best solution. This protects children effectively and remains almost unnoticeable.
