ᐅ How can I modify IKEA Metod cabinets to improve accessibility?
Created on: 15 Jun 2023 08:47
GregorneoG
Gregorneo15 Jun 2023 08:47Hello everyone,
I am planning to modify my IKEA Metod kitchen cabinets to make them more accessible. Specifically, I want to adapt the cabinets and their interior layout for people with limited mobility, possibly even wheelchair users. I am looking for advice on what practical modifications can be made to Metod cabinets to improve accessibility, for example by adjusting handle heights, using pull-out drawers instead of fixed shelves, and tips for installing electric drives or other assistive devices.
Does anyone have experience with modifying these cabinets for accessibility? Which solutions have proven effective, and which ones are less useful? I would greatly appreciate practical advice as well as information on potential challenges, as I have only approached this topic theoretically so far.
Hello Gregorero,
I can recommend a structured approach:
- First: Measure the correct working height (sitting or standing height).
- Replace doors with pull-out cabinets, as these significantly improve accessibility.
- Use internal drawers or wire baskets instead of fixed shelves.
- Handle height: sturdy bar handles, at least 12-15 cm (5-6 inches) long, are much more practical.
- If possible, install cabinets with adjustable height or on supports.
Common mistakes:
- Doors remain too small, limiting access.
- Drawers are too heavy or installed without soft-close mechanisms.
Conclusion: Pull-outs and handles are essential, and the installation height must be individually adapted to the user.
Common mistakes:
Gregorneo15 Jun 2023 10:15klo40 schrieb:
Use pull-out drawers or wire baskets instead of fixed shelves.Thanks, that sounds very practical. I’m particularly interested in whether the Metod modules are generally compatible with electric lift systems. Are there any experiences regarding whether motorized lift doors or extendable elements can be easily retrofitted? Or is that usually too expensive or complicated?
Some accessible kitchens use electric shelving units that can be accessed at the push of a button. It would be interesting to know if Metod provides a good basis for that.
The IKEA Metod series is modular and generally flexible enough for modifications. However, IKEA does not offer any factory-installed motorized lifts or similar systems for these cabinets.
Retrofits are technically possible but require expertise in electromechanics, and the systems must be purchased from third-party suppliers or custom-made.
Important to know:
- The cabinets are usually made with panels 16-19 mm (0.6-0.75 inches) thick, so the limited weight capacity of the doors and drawers must be considered.
- Electric drives require secure mounting, especially regarding safety.
Mechanical pull-outs on rollers or hinged doors with soft-closing mechanisms, which are easy to operate manually, are simpler and more cost-effective.
Important to know:
Lorukeo schrieb:
The IKEA Metod series is modular and actually flexible enough for modifications.The issue here is that IKEA designs are primarily aimed at the average user—accessibility is not their main focus.
So why not choose a system specifically designed for accessibility from the start? Converting Metod might seem practical, but it’s essentially a partial solution that will likely cause problems later on. Electrical components, custom adaptations—you can never implement these as effectively as with specialized providers.
If you truly want accessibility, it’s better to rely on manufacturers with relevant certifications and experience, rather than a DIY approach with Metod.
