ᐅ Reducing the width of an IKEA Pax wardrobe unit
Created on: 27 Jul 2012 12:08
Mikkelinho
Mikkelinho
27 Jul 2012 12:08
Hello dear forum,
I recently moved into a shared apartment and, when assembling my Pax wardrobe (1 unit 1.00m (3 ft 3 in), 1 unit 0.50m (1 ft 8 in)), I was alarmed to find that it doesn’t fit exactly into the space in my room. It is about 1.5 cm (0.6 inches) too wide. Has anyone here ever narrowed down a wardrobe like this, or is there a middle panel that could be used to connect the two units (which would save about 1.5–2 cm (0.6–0.8 inches))?
I would really appreciate any advice.
Mikkelinho
EinrichtungsNiete
27 Jul 2012 14:26
Hello!
First, please measure the gap where the cabinet is supposed to go very carefully (walls can be uneven, I’ve seen it happen before...). Also, measure the exact width of the individual cabinet parts as well as the width of the side panels. How deep is the “gap”? Is it a recess in the wall or just an open space between other furniture?
If the cabinet would fit into the gap once one side panel is removed (but remember you’ll need a bit of clearance to slide it in), here’s what I’d suggest: instead of assembling the two cabinet sections separately, build them together by leaving out one of the two central panels. To do this, drill all necessary holes completely through the remaining central panel so they can be used from both sides.
Just keep one thing in mind: if your cabinet has hinged doors, you’ll need to reduce the width of both doors (cut them down) so they can close properly. If your cabinet has sliding doors, you’ll probably have to modify the sliding tracks so they can be attached to the modified cabinet.
If removing one central panel is not enough, I might have another idea. If it’s a recess in the wall, why not convert the entire recess into a wardrobe? Install shelf support rails on the wall, place shelves on them, and you’re done. If you have sliding doors, with some skill you might even be able to reuse them...
