ᐅ Space-saving construction of IKEA Metod cabinets with sliding doors
Created on: 18 Apr 2022 08:17
Mirita
Hello everyone, I am planning to install Metod cabinets from Ikea with sliding doors in a rather small kitchen, aiming to save as much space as possible. I am especially interested in how to best design the cabinet structure so that the sliding doors operate smoothly and require minimal clearance. Does anyone have experience with the optimal installation of the tracks or tips for handling the doors in tight spaces? Also, how is the stability affected when multiple cabinets with sliding doors are placed side by side? I would appreciate any advice, especially regarding materials or additional solutions that have proven effective.
barEsperan18 Apr 2022 11:42If you are using the cabinet in a narrow kitchen, I recommend designing the doors so that they can slide completely behind each other. This way, no floor space is lost, as is the case with hinged doors.
Super interesting topic! I did exactly this with Metod and installed sliding doors. It’s important to take your time aligning everything. A tip from me: use strips to level the tracks, which makes sliding much smoother. The result is really great because you save a lot of space!
Thanks in advance for the quick replies! I’m specifically wondering about the best way to install the rollers on the tracks when space is limited – does anyone have a recommendation on whether the tracks should be mounted more towards the center or closer to the edge of the cabinet? I’m also interested in whether it makes sense to use the usual Ikea tracks or to consider third-party options when it comes to durability.
Mirita schrieb:
I’m specifically wondering about the best way to install the rollers in the tracks when space is tight—does anyone have recommendations on whether the tracks should be mounted more toward the center or closer to the edges of the cabinet? The guide rails should be mounted as close to the edges of the cabinet as possible. This helps minimize torque. Center-mounted tracks usually require thicker doors and more space for sliding doors.
Mirita schrieb:
I’m also interested in whether it makes sense to go with the usual Ikea tracks or to opt for third-party solutions when it comes to durability. Ikea tracks are solid, but for heavy use and long-term durability, branded hardware products from manufacturers like Hettich or Blum are generally more durable and easier to adjust.
Cecilera6618 Apr 2022 13:28Install close to the edge, otherwise the doors will wobble. Third-party suppliers are often more precise if you want something professional.
