ᐅ Space-saving construction of IKEA Metod cabinets with sliding doors
Created on: 18 Apr 2022 08:17
Mirita
Hello everyone, I am planning to install Metod cabinets from Ikea with sliding doors in a rather small kitchen, aiming to save as much space as possible. I am especially interested in how to best design the cabinet structure so that the sliding doors operate smoothly and require minimal clearance. Does anyone have experience with the optimal installation of the tracks or tips for handling the doors in tight spaces? Also, how is the stability affected when multiple cabinets with sliding doors are placed side by side? I would appreciate any advice, especially regarding materials or additional solutions that have proven effective.
Thanks for the tips, very helpful! One more question for the planning phase: Is it better to build the cabinets with sliding doors as individual units or to install several connected units? I want to keep flexibility in the kitchen design but also prefer a smooth, closed surface. Additionally, how is the stability affected when several units with sliding doors are placed side by side?
barEsperan18 Apr 2022 15:45Several connected units are more stable and create a seamless appearance. Individual cabinets are more flexible, but this can result in small gaps between the doors, which should be avoided.
Mirita schrieb:
For the planning stage, one more question: Is it better to build wardrobes with sliding doors as individual units or to install several connected together? From my own experience, I would say that combining several wardrobes provides more stability and a neater appearance. It feels more solid, and the doors tend to slide more smoothly. On the other hand, this reduces flexibility when rearranging the room. Depending on the room size and possible repurposing, this is a trade-off to consider.
Good morning! One more technical question about the sliding system for Metod: What are the tolerances for the door dimensions that need to be observed? I’m asking because my ceiling height and room depth are quite limited, and I’m not sure how much clearance needs to be allowed for sliding within the tracks. Does anyone have tips on how to cut or adjust the doors precisely to avoid issues with jamming or binding later on?
The tolerances are usually about 2-3 mm (0.08-0.12 inches) of clearance on each side – meaning the width and height should be slightly smaller than the frame. It is important to leave enough space at the top and bottom so that the doors don’t get stuck. For the height, you generally allow about 5 mm (0.2 inches) of clearance from the ceiling/frame to ensure the doors can slide freely. Careful measuring and, if necessary, sanding or adjustments are essential. Precise right-angled cuts are important.
