Hello everyone, I recently got a Kallax shelf from Ikea and have noticed that condensation seems to form on the back panel, which is made of thin wood or particleboard, especially on cooler nights. My main question is: Does anyone have experience with condensation buildup on the Kallax back panel and can share whether this has caused any long-term damage to the material? I am particularly interested in whether the moisture has actually led to warping, mold growth, or other structural issues. Are there any proven methods to prevent or reduce this problem? I look forward to your feedback and advice!
pinJustin8 Sep 2017 18:45I had the same problem back then. Condensation can sometimes cause swelling on Kallax back panels. Just let it dry and use moisture-absorbing pads, and usually, it won’t cause any major damage.
pinJustin schrieb:
Condensation can sometimes cause swelling in Kallax back panels.That is correct, and it largely depends on the room temperature, humidity, and the type of back panel. Kallax back panels are often made of a thin fiberboard without protective coating or sealing, which means they absorb moisture very quickly.
As a result, the material swells, which is clearly noticeable through expanding edges or changes in the panel’s flatness.
The most important aspect is to describe the exact environmental conditions: Is the shelf placed near an exterior wall? How is ventilation managed in the room? Are there heat sources nearby?
The cause of condensation in this area is usually a temperature difference between the back of the panel and the room air, which leads to condensation when humidity levels are high. This can be especially significant in unheated or poorly ventilated rooms.
Long-term damage occurs not only from swelling but also from mold growth if the moisture persists over time. Treating the back panel with a water-repellent finish, or even retrofitting a light-colored, vapor-permeable vapor barrier behind the shelf, can help reduce moisture exposure.
I would ask you to provide more information about how your Kallax is positioned, whether you ventilate regularly, and what the humidity level is in the room.
fidasi schrieb:
The most important point would be to provide an exact description of the environmental conditionsThank you for the hint! The shelf is located in a living room with south-facing windows, which are sometimes slightly tilted open at night. According to a hygrometer, the humidity usually ranges between 45 and 55 percent, but at night it can rise to around 60. The back panel is standard, with no special sealing.
So far, I have not ventilated specifically, only regular airing during the day. Heat sources are about 2 to 3 meters (6.5 to 10 feet) away, and the room temperature is around 20 degrees Celsius (68°F). I assume that the relatively cool exterior wall also plays a role here.
Lorahau schrieb:
The back panel is standard, so no special sealing.This is often where the problem lies. Such thin back panels are already minimally dimensioned and then exposed to moisture without protection – this is almost inevitably an invitation for material damage.
fidasi schrieb:
Treating the back panel with a water-repellent coating can reduce moisture exposure.That is indeed an option, but in a living space with fluctuating humidity and temperature, one could argue that instead of the usual back panel, a vapor-permeable board should be used. Something that can absorb and release moisture without being damaged.
Are there any concrete reports on how long an untreated back panel actually lasts when condensation regularly occurs?
From a technical perspective, it should be noted that Kallax back panels are usually made of thin MDF or particleboard, which is not designed to withstand moisture exposure.
Moisture, especially condensation, can cause swelling within months. This becomes particularly critical if the shelf is located in areas with direct moisture exposure or when there is a large temperature difference in winter.
A simple measure is to treat the back panel before installation with a water-repellent varnish or wood preservative. Alternatively, breathable membranes or thin hardboard panels are suitable options, as they handle moisture better.
Long-term damage such as warping and mold is unfortunately common with untreated back panels. Therefore, I recommend not placing the shelf directly against cold exterior walls and ensuring sufficient ventilation.
