ᐅ Is it practical to nail a KALLAX back panel between modules?
Created on: 14 Jul 2020 08:37
sikareo
sikareo
14 Jul 2020 08:37
Hello everyone, I have a question that has been on my mind recently: Is it really practical and advisable to fasten the back panels of IKEA KALLAX units together by nailing or using similar methods when assembling multiple modules? Specifically, I’m referring to the thin OSB boards that serve as the back panels of each KALLAX unit—when placing several modules side by side or stacked, it’s theoretically possible to screw or nail these back panels together.
I’m asking because, on one hand, I want a stable construction, especially if the assembly needs to be moved or is expected to bear heavy loads. On the other hand, I’m wondering if this method might damage the back panels, make the boxes harder to remove, or make the shelf more expensive or complicated to repair in case of minor damage.
Has anyone had experience nailing together KALLAX back panels between modules and can say whether it actually makes sense in terms of stability, durability, and practical use? Are there perhaps better alternatives? I would appreciate a detailed assessment!
bulanau
14 Jul 2020 10:01
Basically, it can be said that nailing the back panels together between KALLAX units makes sense if you want to stabilize a shelving system made up of multiple units as a single structure.
Why? The back panels, made of thin OSB, are quite delicate on their own and primarily serve to stabilize each individual unit against twisting. When several units stand side by side and you want to move them, they may shift against each other, which over time can reduce stability and cause wobbling. By connecting the back panels, you create a composite structure that reduces such movements.
The downside is that the back panels get damaged. To minimize this, I recommend using small through-nails (not thick screws) in the overlapping areas. If needed, I can provide more detailed guidance on exact nail placement.
In summary: Yes, nailing them together can be useful, especially for larger assemblies. However, if you need flexibility or want to use the units individually, it’s better to avoid it.
FEKAU
14 Jul 2020 11:15
To answer the question as precisely and clearly as possible: the back panels of the KALLAX shelves are not designed for permanently connecting the modules. Their primary function is to stabilize the side walls of each individual module against twisting.
Nailing the modules together increases the overall stiffness of the assembled unit, which can be beneficial if the shelving is in a fixed location and used consistently. However, it should be considered that nailed connections often lack flexibility: stresses caused by temperature changes or slight settling need to be taken into account, as they can otherwise cause damage to the OSB boards or even at the module joints.
One possible alternative is to mechanically connect the modules using common furniture connectors (e.g., biscuits or brackets) without damaging the backing panels. This method provides a stable connection while still allowing the modules to be separated if needed.
In summary: nailing the modules together makes sense for a fixed setup but is not ideal. For flexibility and long-term use, I recommend mechanical connectors that do not damage the back panels.
lubla
14 Jul 2020 11:48
If you don’t want to disassemble the modules frequently, you can nail the back panels together. This makes the unit more stable, but the back panels will be damaged, and repairs will be more difficult. For frequent use, it’s better to use clip-on or screwed connectors.
Foster63
14 Jul 2020 12:53
I would like to add that the structural effectiveness of a back panel connection created by nailing can be quite high, especially with longer KALLAX assemblies.
However, the type of connection should be chosen carefully to avoid splitting or cracking the OSB boards. Fine nails, small screws with washers, or special furniture connectors are better suited than large nails.
The installation location and the load on the shelving unit should also be taken into account. In a rental apartment, where the modules might be rearranged more frequently, a fixed connection is less practical than in a permanent setup.
Demetrius
15 Jul 2020 08:07
For me, practicality is always important with a topic like this. I once tried to connect two KALLAX units using the back panels to increase stability. My experience was that it worked well at first—the shelf stood firmer and wobbled less.
However, taking them apart later became difficult because the back panels had become quite brittle, especially after multiple moves. Therefore, I would recommend to anyone who doesn’t want to fully commit to a fixed connection for stability to rather use screw connectors and avoid relying on the back panels solely as stability elements.
What about you? Do you really use the back panels as connectors between units, or mostly just as stabilizers for individual modules?
