ᐅ Kallax Back Panel Replaced – Still Dust Inside the Compartment
Created on: 10 Nov 2022 09:32
neose2Hello everyone,
I recently replaced the entire back panel of my Ikea Kallax shelf unit because the old one was very worn and partly damaged. Despite this replacement, I still notice a considerable amount of dust accumulating inside the individual compartments—much more than I expected. I understand that dust can never be completely avoided, but I had hoped that the new back panel would at least reduce the dust entering areas where there used to be larger gaps and cracks.
Does anyone have experience with why so much dust still gets inside the compartments? Could it be due to the shelf’s construction, the back panel itself, or are there other common causes? I would appreciate any advice, including suggestions for more effective dust prevention with the Kallax.
Thank you in advance!
baAlejandr10 Nov 2022 11:05Good morning,
first of all, it is important to understand that the Kallax shelf is an open design that relies on backing panels made of thin material. Even if the backing panel is new and intact, there are often small gaps at the side joints and the bottom panel that can allow dust to pass through.
Furthermore, dust accumulates not only from the outside but also through air circulation in the room, which affects every surface. The backing panel can never seal completely, especially since it is usually just placed or fixed with small nails.
An interesting option would be to seal the edges with self-adhesive sealing tape or a thin foam rubber strip. Alternatively, a plexiglass sheet behind the compartment could be considered if it really needs to stay dust-free.
This is actually a more complex topic than it appears at first glance. In shelves like the Kallax, the back panel is usually made of a thin MDF or particleboard sheet, which is simply inserted into a groove or fixed with small nails. This construction is primarily designed to provide stability, not to create an airtight seal.
Dust particles are very small, ranging from about 0.1 to 10 micrometers. They can easily enter through tiny gaps, especially at the joints between the back panel, side panels, and bottom boards. Even if the back panel is new, uneven edges or not fully flush connections can create such gaps.
It is also interesting to consider how the shelf is positioned in the room: Is it close to a ventilation opening, radiator, or windows? Air circulation increases dust movement and continuously brings in more dust.
To approach the problem systematically, it would be helpful if you could carefully check exactly where the dust is coming from—such as on the surface of the back panel or along the edges. A visual inspection with a bright light along the seams can also reveal possible gaps.
Additionally, you could try applying a thin layer of acrylic sealant or caulk along the edges of the back panel to seal the gaps—a labor-intensive step, but effective against dust infiltration.
I would like to add that dust will probably never be completely avoidable, but you can slightly reduce the chance of it getting into the compartment. Also check if the shelf itself wobbles or can be easily moved, as this can create gaps that are not immediately visible.
The surface texture of the back panel and edges can also attract or repel dust. A smooth, sealed board often collects less than a raw wood surface.
Regarding cleaning: dust dislikes static electricity. A slightly damp cloth can help remove the particles more effectively. Sometimes the problem is that existing dust gets stirred up when opening and handling the compartment.
So if you handle the compartments frequently, dust will settle more often.
baAlejandr schrieb:
The back panel can never be completely sealed.That makes sense to me, thank you for the clarification!
I don’t have ventilation nearby; the shelf is placed against a wall that is occasionally aired. There is a radiator a few meters (yards) away, but not directly next to it.
Gafiel schrieb:
Dust particles are very small, about 0.1 to 10 micrometers. They can pass through tiny gaps.That explains a lot, I didn’t realize the back panel was as vulnerable as I thought. The idea of using sealant sounds interesting, but I’m worried it might reduce the shelf’s mobility.
Are there other materials for back panels that provide better sealing? Maybe a combination of MDF and a gasket?
