ᐅ Is it advisable to securely screw the KALLAX back panel in place?
Created on: 28 Aug 2024 09:17
Pierresu
Pierresu
28 Aug 2024 09:17
Hello everyone, I am currently considering adding a fixed back panel to my IKEA KALLAX shelves and wondering if it really makes sense. My idea is to increase the stability of the shelf and prevent bending or warping, especially when it is loaded with heavier items. On the other hand, I am concerned that this might make assembly or future adjustments more difficult, and whether it could potentially damage the shelf or cause other disadvantages. Does anyone have experience with this or can offer advice on whether it is generally beneficial to use a fixed back panel for KALLAX shelves, or if it is better to stick with the original, simply slotted-in back panels? Thanks in advance!
Dustin
28 Aug 2024 09:46
Permanently screwed back panels definitely make the shelf more stable and prevent warping. If you plan to load the shelf with heavy items over a long period, this is recommended.
KAULIS
28 Aug 2024 10:12
A firmly screwed back panel primarily increases the torsional rigidity of the shelving unit. The original back panel in KALLAX is usually just inserted and mainly provides light stabilization and helps keep it properly aligned. For heavy loads, retrofitting is definitely advisable. However, it is important to use appropriate screws and avoid ones that are too long, as they could damage the material.
BARSAN
28 Aug 2024 10:43
I have securely screwed the shelf in place, and it is now much more stable. No more wobbling, even when fully loaded.
GiRoyce
28 Aug 2024 11:20
The question of whether a fixed screwed back panel is worthwhile is certainly valid. In general, the original KALLAX back panels are thin and mainly serve to complete the appearance and provide slight stability. If you plan to heavily load the shelf, for example with heavy books or décor, then a fixed screwed back panel is definitely beneficial for durability and prevents significant warping, which can particularly be an issue with wider shelves.
However, when screwing it on, be careful not to split the carcass material. It is better to pre-drill and use small screws. If flexibility is important to you, fixing the back panel with screws might cause problems later, as the shelf will no longer be easily disassembled or modified.
Nabla64
28 Aug 2024 12:06
A brief guide if you decide to go with a fixed screw connection:
1. Prepare the material: Use thin plywood or multiplex panels as the back panel, which are more stable than the original thin KALLAX back panel.
2. Screws and pre-drilling: Use thin Spax screws (about 3.5 mm (0.14 inches) in diameter), preferably with a countersunk head. Don’t forget to pre-drill to about 70-80% of the screw length to avoid splitting the wood.
3. Positioning: Screw the back panel so that the screws are not too close to the edge, preventing the material from cracking.
4. Number of screws: Depending on the size of the shelf, distribute 8 to 12 screws evenly to secure the back panel.
5. Assembly: It’s best to assemble the shelf lying down to ensure everything is fixed evenly and without warping.
This method increases rigidity and prevents the shelf from twisting or warping under load. Overall, a good compromise between stability and maintaining some flexibility.
